Dr Frankenstein's CIC Retrofit
Old 12-06-2014, 05:07 AM
  #21
djcwardog's Avatar
My Ride: 2007 E63, loaded, 6M, Sport, CIC/combox, DIRAC retrofitted.
Originally Posted by addy33
And you also have to change the NVC setting in the CIC trace file from wert 23 to wert 21. Use ncsexpert and ncsdummy for this to make it easier to retrieve and manipulate try files.
I just saw this thread come up in a search, so I thought I would confirm that NIVI function is restored when you move the pins as above - and in referenced thread - and change coding in CIC so NIVI and TV are both at "wert_21". TVC stays at "255" and TVM is "kein_TVM" This worked for my US-spec car that came with Night Vision as OEM but no TV Tuner option (like the cars in Europe might have...).
Old 02-21-2016, 07:36 PM
  #22
richie281vn's Avatar
My Ride: 2006 525i
Model Year: 206
Subcribed.
Could I please clarify that E91 CIC will not snap-fit Pre-LCI E60?
Old 08-22-2016, 11:36 PM
  #23
My Ride: 2006 525i
Model Year: 206
BUmp
Old 07-19-2017, 05:16 AM
  #24
mybeemer's Avatar
My Ride: BMW E60 M-SPORT 520D
do you know if the front panel from e60 LCI MASK unit can be retrofitted to CIC as it looks identical?
Old 03-06-2018, 11:48 AM
  #25
youngbmw's Avatar
My Ride: e60 520d lci
Model Year: 2010
ive heard several people mention that the e90 cic will not work with an e60 car, is this correct? i can sclearly see that it worked here but is there something special which you have done
Old 11-12-2018, 10:06 AM
  #26
Reefin Dude's Avatar
My Ride: E61. all of the options that were available.
i have been trying to get this to work after a CIC retrofit, and i just can not get night vision to work. i have changed the pin location, but if the following does not work, i will triple check that i did it right.
i was hoping someone could confirm the following nomenclature for these settings.
i can not find a NIVI only in the CIC, but in other posts around the webs i think it is called NVC, is this correct?
the only NIVI's i have found are:
MACRO_NIVI
aktiv
MACRO_NIVICAM_I_DISCLAIMER
ld_mit_timeout
NIVI_2_OBJ_DETETECTION
nicht_aktiv
i have changed NVC and TV to wert_21
TVC is set to wert_255
i could not find a TVM, but could fine a TVM_VARIANTEN and i did set that to kein_tvm that is the only TVM in the CIC i could find.
i have confirmed that these settings are in the CIC after pulling another .TRC file from the CIC.
G~
Kaane
03-15-2022 05:16 AM
jcolley
08-01-2016 06:48 AM
bestofthebest
03-28-2016 02:47 PM
Bank$hot530
09-16-2015 01:28 PM
Quick Reply: Dr Frankenstein's CIC Retrofit
