DIY ZF 6HP19Z Transmission Drain & Refill
Old 09-20-2016, 10:39 PM
  #341
roadmax's Avatar
My Ride: E60 550i
Model Year: 08
What does the pan/filter kit contain? Does it come with seals and screws?
Old 09-21-2016, 03:17 AM
  #342
KyleB's Avatar
My Ride: 530i
Engine: M54
no screws, but it will come with the pan gasket.
Old 09-21-2016, 06:37 AM
  #343
gcalo's Avatar
My Ride: 530i
Engine: N52
I ran my finger along the pan seal 1st to ensure it was seated properly, and then again with tranny fluid to moisten the seal before installing it.
Old 09-02-2017, 08:42 AM
  #344
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
Can someone help me how to read TFT on this interface I am seeing in INPA? Everyone else seems to see windows with progress bars rather than numbers like me. My INPA version is 5.0.6
thanks
Old 09-03-2017, 10:30 AM
  #345
salaki's Avatar
My Ride: 05 545i 6MT
I did the same on my buddy's 2008 E60 528i w/ 6 Speed Auto (110k miles).
I flushed the fluid w/ Valvoline Maxlife ATF(via transmission cooler line. Buy the tool to remove the cooler line!) until the fluid came out RED clean.
BMW Transmission line tool:
Amazon Amazon
I also changed the bulkhead connector seal, transmission filter and reset transmission adaptation and filled at correct fluid temperature.
Bulkhead connector seal:
In the beginning, it shifted really hard, but after couple of days drive cycle, it now shifts very smooth (but fast) than old ZF fluid.
This Maxlife is full synthetic and should last longer than the ZF.
I saved Valvoline's response listing this transmission fluid is approved for use in BMW LT71141, LA2634, M-1375.4, ATF 3.0.
Now the car has been running w/ Valvoline Maxlife ATF for about 15k miles w/o issue,
Old 09-03-2017, 10:37 AM
  #346
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
In the beginning, it shifted really hard, but after 1 week, it now shifts very smooth (but fast) than old ZF fluid.
Did you keep track of fluid temperature using a thermometer or INPA?
thanks
Old 09-03-2017, 10:51 AM
  #347
salaki's Avatar
thanks
I used the kitchen meat thermometer probe and stick into the transmission fill plug to monitor the fluid temp.
Just make sure you jack up the car evenly
Check this video out:
Old 06-30-2018, 12:06 AM
  #348
Jnelson1182's Avatar
My Ride: BMW 525I
this may sound like a very dumb question but I have a 2004 525i & was wondering if theres any way for me to check the fluid level in my transmission besides draining it? I was also wondering where it is that I add tranny fluid on this vehicle?
Old 06-30-2018, 06:27 AM
  #349
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
Check here, a great resource for our transmissions.
Old 06-05-2019, 10:58 AM
  #350
HollowPoint503's Avatar
My Ride: Jet Black 2006 525i: Cold Weather Package, HUD, Navigation System, Adaptive Xenon Headlights, Premium Sound System.
Im about to attempt this service myself on my car. Im just over 150k miles. I watched all the old Bav Auto DIY videos before realizing the E60s have a different transmission, and have since watched multiple videos on E60 transmission fluid and filter changes. The only thing I'm unclear on is, do we have a separate pan gasket like older model BMWs? The pan I bought looks like it has one built in.
Quick Reply: DIY ZF 6HP19Z Transmission Drain & Refill
