DIY ZF 6HP19Z Transmission Drain & Refill
My Ride: 2004 545i Sport, ti silver/gray, CWP, Logic 7, PDC, Nav, elec shade, lumbar, FDRS
2000 Honda CBR 929
1999 Lexus GS400, Nakamichi
Now I know why it costs $800.
My Ride: E60 530i
Engine: M54
Did mine at 50k miles but did not replace the oil pan. Will do the oil pan replacement @ 100k miles. Thanks for the tip to expose all the oil pan screws.
Raj
My Ride: E60 530i
Engine: M54
Originally Posted by 968turboS' post='1040629' date='Oct 26 2009, 11:26 AM
My pleasure. What was your fluid like at 50K?
Raj
Raj
https://5series.net/forums/index.php?showto...1&hl=lcc014
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
This is great, I've been pondering this job myself. 5.5 liters of transmission fluid, that is a lot.
Couple of questions. 1, what is the reason for replacing the pan? 2. is there a gasket or seal for the pan that must also be replaced?
thanks.
thanks.
thanks.
thanks.
1. If you want to replace the filter, you will have to replace the pan. They are both 1 piece now. Since all the gunk gets caught up in the filter, I felt it made sense to change it.
2. I bought the pan kit which included everything. If you are ok with reusing your old pan, you can purchase all the gaskets and seals seperately.
Another suggestion for people that are concerned about warranty would be for them to just drain and fill ATF for now, change the pan at 100k.
Regards.
Raj
Originally Posted by jim_in_calgary' post='1041004' date='Oct 26 2009, 10:39 PM
Thanks for this.
Did you examine the filter? Was there much gunk in it?
Raj
