DIY ZF 6HP19Z Transmission Drain & Refill
#141
I recently did a pan and fluid change for my 6HP26 using the excellent info from this post. I also ordered the mechatronics sleeve, but since it was not leaking, not even a little, I did not replace it. The refill was more difficult than I thought it would be and I ended up spilling about half a liter of the fluid on the floor. A hot exhaust pipe on the V8 runs right by the drain plug and I also got a bit of a burn from it. The car was on jack stands which made the job a lot harder than it would be on a lift. I strongly recommend using a lift for this job if you can borrow one or rent time on one.
Out of curiosity, I broke open the old plastic oil pan to check out the filter. I was surprised at how clean it was, it looked white, like new. Aside from some very fine metal powder on the magnets, the pan & filter were very clean. I drive my car pretty hard at times and expected to see a lot more evidence of it than I did. So, unless you are totally obsessed with tranmission fluid cleanliness, I would suggest that replacing the pan/ filter combo is not terribly important and could probably be skipped.
I also recommend that anyone replacing the pan & filter order at least 5 of the pan bolts. (I think someone else on this board recommended that, but I missed that post until after I had started the job.) I had a few bolts that were a bit corroded, difficult to remove and should have been replaced, but since I doubt I will replace the pan again, I didn't think it was all that important.
How much fluid did you put in before starting the car? The reason why I ask is because my transmission has been leaking fluid slowly through the gasket, I supposed, so using the measuring how much fluid drained method might not be correct for me. Just want to get some ball park figure since I will have to fill it to the max when it gets hot. .
#142
There is a company here in So Cal that rents space and tools in a garage and they also have a lift. They get around $230 for a full day and prpoportionally less for partial day. Of course I did not mean to rent a lift for use at your own garage!
#143
#144
Thanks for the quick reply GWF...need to tackle this project soon. Order the ZF transmission kit already. Stop by local auto store but they didn't have the fluid transfer bottle. Need to find a bigger store somewhere in the Bay Area when I head down there this coming week.
BTW, how did you measure the temp of the trans fluid when refilling?
#145
#146
My Ride: E60 530i
Engine: M54
That is good, wish we have this kind of rental company in Massachusetts
#147
Where is the best location to put the jack stand at all 4 corners? I was thinking of instead of using jack stand, can I use stack of 2x10, 4 or possibly 5 nailed together, underneath each wheel for stability. Considering the current underneath clearance along with another 6" from 4 pieces of 2x10, I will get around 10 inches of clearance which, I think, is sufficient enough for me to work with.
Any opinion or additional advice guys? Never try to lift a car at all 4 corners before.
#148
My plan is to jack under the front jacking points using two trolley jacks, then use a bottle jack under the central jacking point to hold the car whilst I swap the trolley jacks for axle stands. The axle stands will then be on the proper jacking points.
Then repeat at the rear (here you have to use the differential, avoiding the fins).
#149
The problem with this idea is that the car suspension hangs down when you jack it up so you won't get much under the wheels. When you lower it again the suspension will compress. You might get 4" but that's not much.
I first thought about the sagging suspension issue but the logic here is if I parked my car on a flat surface, it has approximately 3 to 4 inch clearance right now. If I jack up the car and put approximately 6 to 8 of wood underneath the tires at al 4 corners, wouldn't this be the same as parking on a flat surface except the surface now is raised up. At least in theory it should work unless gravity is that much more when the car is 6 to 8 inches more off the ground.
BTW, where exactly is a safe point underneath the body of the car for the jack stand? I doubt the current jack points are the safe spot since it seems like it's made out of plastic and the jack stand's tip does not fit into the slot like the jack that comes with the car.
Sorry for asking too many question on the jacking issue alone.
Thanks
#150
Those plastic jacking points really are the best place. I put a small piece of wood in mine to fill the hole then use a trolley jack. Not totally necessary though.
At the front in the middle theres a cross member, perhaps 36" in from the front bumper it has a big square of plastic on it for lifting the car. The trouble is if you use a trolley jack and the wheels don't roll smoothly the arcing of the jack arm can pull it off the block. It's really meant for a vertical lift when on ramps.
The rear differential casing is the equivalent at the rear, but the solid part not the fins.
