DIY ZF 6HP19Z Transmission Drain & Refill
Old Apr 6, 2011 | 06:21 AM
  #121
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by pcy
Hi,
I am planning to change trans filter/pan and the trans fluid in my '06 530i with 95K miles.
For the filter/pan, ZF brand pan/gasket/seal ring is available for around $170. BECK/ARNEY brand pan/filter/gasket/seal ring for around $99.
Anyone used BECK/ARNEY brand? Would you recommend this product?
For the trans fluid, Pentosin is around $15 per Ltr, Shell-M is around $27 per Ltr. Any reason why I shouldn't use Pentosin?
Most people use Pentosin including me. I have not changed the filter/pan yet, I will do that when car reach around 100k miles. I will go for ZF band instead of BECK/ARNEY; just for peace of mind.
Old Apr 6, 2011 | 07:03 AM
  #122
pcy's Avatar
pcy
thanks for your input. I will go with ZF filter/pan.
Old Apr 12, 2011 | 02:06 PM
  #123
525iEnjoy's Avatar
Well just did control arms etc.. and now Trans pan is Super wet dont you hate that lol So I have an appointment to verify if this service is needed from an Independent shop or if its something else causing. I have ordered the Motorcraft Mercon SP after reading all threads and google. Its on my dime so I am going to use less dimes on fluid and more dimes towards parts and labor. Less than 5 bucks is awesome! Great write up
Old Apr 13, 2011 | 04:39 AM
  #124
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Did you mean the tranny pan leaked tranny fluid ?
Old Apr 13, 2011 | 06:35 AM
  #125
525iEnjoy's Avatar
Yes Its seeping a little bit . My plastic cover is damp so
Old Apr 13, 2011 | 07:13 AM
  #126
lcc014's Avatar
My Ride: E60 530i
Engine: M54
IC. Did you trace the fluid to see where it came out ?
Old Apr 13, 2011 | 07:33 AM
  #127
525iEnjoy's Avatar
nothing from the top looks like pan plug or top of pan will know more tomorrow.
Old Apr 19, 2011 | 07:57 PM
  #128
idouoooo's Avatar
is it possible to overfill the transmission oil and cause damage to gearbox or any of its affiliated systems that run on ATF??
also, would not having sufficient oil in the trans be the/a cause for vehicle not shifting into gear?
Old Apr 20, 2011 | 06:54 AM
  #129
525iEnjoy's Avatar
There is a dipstick? And possibly yes low could effect shifting. Have it checked.
On a side note the Fabled Mercon SP is here! I feel like a rebel. The pan kit should be here today for installation on Saturday! For anyone who would like to see data sheets for comparisons of Mercon SP, Royal Purple ATF, Ams Oil to Pentosin/ZFlifeguard6 hit me up
Old Apr 20, 2011 | 10:22 AM
  #130
idouoooo's Avatar
so i went to BMW to buy some ATF and was told they only sell the 5 gallon jug. I only need a QT or so...what gives!!!
