DIY maintenance for the DPF...
#201
#204
My Ride: Bmw 530d 2004
- Antti -
#205
Hi Antti.
Out of interest what temp does your coolant get up to where you are up ?
He in the UK we had a period of 0C or there abouts for a couple of weeks and my car could barely reach 70C on occasion whilst on the highway. Ive had new thermostats only 6 months ago.
The tempretures have warmed here to around 6C and it heats back up to 88C no problem at all.
From what Ive seen on my car the temps go up to around the 80C mark, stay there for a while then go up to the high 80's.
It may be my imagination but my car seems to be attempting regens but not completing them, Im wondering if our 'cold' snap has done the DPF no favours.
Thanks
Neil
Thanks
Neil
#206
Hello Neil!
My engine runs at 86-88°C at summer time, at 83-86°C when the weather is around 0°C, and 78-83°C when it's colder, like -20°C to -30°C.
Along the EGR thermostat and the main thermostat, there's a third one in the automatic transmission and it's called heat exchanger. Here, part #1.
Why do you believe your car attempted the regeneration?
Also, remember that the exhaust gases temperature has to be over 240°C as well as the engine coolant has to be over 75°C for ECU allowing the regeneration to start.
- Antti -
- Antti -
#207
Hello !
I live in France (Metz) and outside it's approximately 0 degrés Celsius ...
My car (325d e90) has now around 100 000km, and i have change the 2 thermostats.
you can see somes pics here : thermostats change
Now after 10-12 kilometers the motor is a 75degrés and when the temps stabilize around 87 - 92 degrés.(no matters with driving style, it warms up the same way...)
So i recommand to change the 2 thermostat.
Anzafin > The third one that you show, is just an heat exchanger, and ther is no thermostat inside ?? It's just here to maintain the oil in the autogearbox around 90 degrés i think ??
#208
Hello !
- Antti -
#209
Thanks for your reply Antti.
Wow It gets properly cold up there. I find firm acceleration puts heat into the car quickest, cruising or deceleration (foot off throttle) really encourages the car to cool down.
What I am trying to describe is the regen commencing near the end of a journey, the familiar feeling as it does so - running 94C - throttle lag - dropping a gear - smell of plastic burning and extremely hot tail pipes - do this for say the last 5 mins of a journey. Then when I stop the car, restart later it doesn't recommends the regen. It may then do this a 2/3 times over a 2 week period. Just feels as though it isn't doing a full 30 minute regen cycle like it has done in the past.
Interesting about the gearbox heat exchanger, i shall research.
#210
My Ride: E60 530d 218ps
Quick question
My E60 530d has 192,000km and iDrive is telling me the dpf needs replacing (?1500+)
What choices do I have? As I've never encountered dpf errors before will a clean / forced regen / resetting of errors work in my case?
If that doesn't work then I suppose my realistic option is a physical dpf delete and ecu recoding then?
