DIY: Cleaning VANOS Solenoids
Old 02-01-2012, 06:06 PM
  #21
black360's Avatar
My Ride: 2006 525i
after receiving the same codes i used this DIY and cleaned mine,,, boy what a difference..even better gas mileage. Thanks so much
Old 06-03-2012, 05:48 PM
  #22
umermariner's Avatar
Just did that today... didnt apply the voltage to open the solenoids or the compressed air, left them in gasoline for like 10-20 mins... BTW, how much are they?
It seems like the light used to come back when driving grany style, and would go after a while when you push the car ... Normally, I dont usually drive outside 1K to 2K RPM, unless I am in 6th gear or in race mode
Took a test drive (couple of miles), every thing seemed good.. no engine light yet... will find out in next few days .
While at it, I also changed oil/ oil filter and cleaned MAF..
I just bought my scanner ... I wish I knew earlier about INPA... seems great... I was also planning to get NCSExpert for BMW coding, I guess same cable can be used for both purposes?
Is INPA is just for scanning codes or also for coding?
Keeping my fingers crossed :$... I have to pass inspection in next few weeks
Old 03-10-2013, 09:54 AM
  #23
DBU
DBU's Avatar
I realize this is an old(er) thread. I have a 2007 X3Si that threw an EML light and severe loss of power. The Stealership found a 2A82 code and recommended replacement of both Vanos solenoids. This is apparently not covered under the CPO warranty (really???) and they quoted $769 to replace both solenoids. I declined. Knowledge is power!
Old 03-11-2013, 12:35 AM
  #24
Yes it is
Old 01-02-2014, 07:40 AM
  #25
WannaBeamer's Avatar
My Ride: 2007 550i, Silver, LOADED
+1 for this detailed DIY write up.
It was very helpful for me as I a still learning the nuances of the Bimmer world!
Cheers!!
Old 09-25-2019, 04:46 PM
  #26
Ahmad K Salim's Avatar
My Ride: 2008 520i full option except for sunroof with 6 speed manual
thank you
Old 09-26-2019, 03:54 PM
  #27
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
For those of you who are familiar with the YouTube sensation from the UK (who calls himself the BMW Doctor), he's got a new video out about the e60 vanos problems.
He's claiming (one one of his long rants) any type of vanos cleaning is a waste of time and will produce zero results.
Additionally, its imperative to buy new vanos OEM sensors or the engine will never run correctly.
Its logical to think that the vanos sensors and eccentric shaft sensor would last longer if your changed your oil at much shorter intervals?
Old 10-05-2019, 01:24 PM
  #28
My Ride: 528i
Engine: N52k
How many guys have cleaned the vanos filters? That is, the non return valves adjacent to the vanos solenoids?
Will cleaning the vanos filters be more effective than cleaning the vanos solenoids?
What's the more effective method?
e6t.lab.rat
DIY: Do It Yourself
74
05-14-2021 08:00 PM
tjkarch60
DIY: Do It Yourself
05-02-2016 07:53 PM
aw3964
12-25-2014 02:02 AM
5zeries
06-03-2014 09:00 AM
Ricapar
01-25-2012 01:58 PM
Quick Reply: DIY: Cleaning VANOS Solenoids
