DIY: Brakes Replacement & Painting the Calipers
Old 10-28-2010, 06:11 AM
  #51
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by 525iEnjoy
Caliper mounting bolts I have @ 90ft lbs in standard.
From TIS, the value is 110Nm or 81 FtLb. The value for 6mm hex screw is 16Nm or 11.8 FtLb.
Old 10-28-2010, 04:37 PM
  #52
carfucious's Avatar
That is what I was concerned with... You may want to treat the allen screw as a more as a locator pin and leave it loose, actually backed out a turn, otherwise it can cause binding issues when you are reattaching the wheel. You would want to make sure that the head of the screw doesn't protrude above the face, otherwise that would create other alignment issues.
Old 10-22-2011, 06:29 PM
  #53
roboe60's Avatar
My Ride: 2005 530i, Premium Package, Grey Leather, Rear Euro Reflectors
Originally Posted by SmithsonGA
I just did my rear brake pads this weekend (not rotors, just pads).
I thought I would share some thoughts/experiences. I am an avid DIY, but this was my first BMW work. '07 550i.
First off, I jacked up the car using my Sears hydraulic car jack...has a round ring that lifts the vehicle. Well, I used the jack point, but BMW uses that form fit rectangular plastic piece that fits their spare jack perfectly. My round jack dug into that plastic some. Funny, but this was the most nerve racking part..actually jacking up the car. The suspension took a lot of jacking before the wheel really started to lift. I dont know, I have changed a lot of tires in my days, but this one seemed more trouble. What jacking point does everyone else use?
I used the TIS and since I was not replacing the rotors, I just removed the guide bolts..that was very easy. However, removing the 'tension spring' was not. I tried all different angles/methods with a screw driver, but couldnt figure it out. Finally I was able to pop it out by twisting where the spring is held in the caliper 'hole' and popped it out. Easy now, just didnt know the trick.
well, then the caliper should just 'slide back' and come off. Well, no. It took a rubber mallet and nut driver (to hammer on) and got the caliper to push off.
I kept the piston side brake pad installed and using a c-clamp, pressed it all the way back. I had already opened the brake reservoir (by removing the entire interior filter assembly, which was easy). I was amazed that the brake fluid basically didnt rise much at all.
then I removed the pad, cleaned up the caliper a bit and put on some anti-squeal grease on the areas mentioned in the TIS. Installed the new pads, slide the caliper back on and reinstalled the guide bolts. The new sensor was also easy.
The most tiring was getting the tire back on! haha.
I was able to reset the idrive easy enough. It says 31000 miles now. Nice.
I will be definitely doing the front brakes in 15000 miles or so and I plan on bleeding my own brakes.
As I said, I am curious where others use as a jacking point assuming they dont use the spare tire cheapo jack.
Oh, and this must be the dirtiest job possible.
thx
No kidding about putting the tire back on. Too bad the E60 tool kit does not contain the guide to mount the wheel like the E38 tool kit does.
Attached Thumbnails DIY: Brakes Replacement & Painting the Calipers-e38-tool-kit.jpg
Old 10-25-2011, 02:25 AM
  #54
tonyb635's Avatar
That little PITA screw in the rotor can easily be removed with one of these and this tool is very cheap (impact driver). Any local auto store should have them. I bought one long ago at a cheap tool store and it still works like new and is worth its weight in gold. Even if you don't need it for the rotor screw, it can come in handy for so many other hard to get out items. All you do is insert the correct tip put on a pair of gloves for safety. Put the tool with tip into the screw and hit the impact driver with a hammer.
http://www.autozone.com/autozone/acc...r-Set/_/N-25dw
Old 12-05-2011, 10:49 PM
  #55
BMWDANQ's Avatar
Thanks for the DIY, I will be doing a complete brake job very soon. Painting the calipers too.
Old 01-05-2012, 07:25 AM
  #56
camshaft's Avatar
Great write up. I'll be doing this either tonight or over the weekend. Have the R1 slotted and drilled rotors, and the R1 brand ceramic pads....from what I understand they are just centric ceramic posi quiet pads. Interested to see what my dust situation is. I have powder coated my wheels in shiny black.......dust magnets. I'll let ya'll know how it goes.
Old 01-06-2012, 07:10 AM
  #57
camshaft's Avatar
Easy breezy install. Put some wd-40 on those pesky rotor screws and used an impact, came off smooth as silk. Loud brakes at first but after a few stops they started to bed in. Smooth and quiet. Installed a new sensor. I wasn't sure if I need one or two sensors for the front, so I bought two. You only need one. Reset the brake warning on the odometer and am good to go. Here are a couple pics.
Attached Thumbnails DIY: Brakes Replacement & Painting the Calipers-2012-01-05-15.25.51.jpg   DIY: Brakes Replacement & Painting the Calipers-2012-01-05-15.36.07.jpg   DIY: Brakes Replacement & Painting the Calipers-2012-01-05-17.58.06.jpg   DIY: Brakes Replacement & Painting the Calipers-2012-01-05-20.32.20.jpg
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
umnitza
03-07-2015 01:53 PM
carid
03-06-2015 04:58 AM
08-12-2003 11:41 AM
Quick Reply: DIY: Brakes Replacement & Painting the Calipers
