Diversity Amplifier Replacement
Old Apr 6, 2011 | 02:07 PM
  #31
azstar's Avatar
These amps retail around £113 from BMW.
What frequency do you have written on your keys? I have new amp for sale for a lot less than rrp that I baught in error
Old Jul 3, 2011 | 03:20 PM
  #32
Ik1's Avatar
Ik1
Azstar did getting the 800 MHz sort you central locking issues out
It's just I think I have done the same as u I went and brought a 300
MHz aerial when I needed a 800 one. So just wanted to find out
Wether it ended up working for u before I shed some more money.
Old Jul 4, 2011 | 12:16 PM
  #33
Ik1's Avatar
Ik1
bump
Old Jul 9, 2011 | 05:50 PM
  #34
azstar's Avatar
Not got round to buying an 800MHz amp yet, although it is well documented on this site that a faulty diversity amp is most likely the cause of poor remote range.
Old Feb 28, 2012 | 02:29 PM
  #35
the awakening's Avatar
My Ride: 2004 525i 1997 318ti - Sold 1990 535i - Gone
Curmudgeon mentioned this a couple years ago but anyone looking to replace the diversity antenna should definitely try cleaning the contacts. I used 91% isopropyl alcohol to thoroughly clean the metal "fingers" on both the car and the diversity antenna. My radio is now back to working 100%. Whereas I would literally get only one station before, I now get all stations that I should. Worth a shot before blowing $150+ on a replacement part.
Old Mar 12, 2013 | 12:42 PM
  #36
Maky's Avatar
Mine started to play up over the last few weeks and i couldnt take it anymore, i thought i would whip out mine and give the contacts a clean, i cleaned them with good old cif/jif cream cleaner on the end of a cotton bud, did the same with the connections on the car. i actually pulled out the little fingers very carefully upwards to give a better connection. Thought i would try this before wasting money on a new one, RESULT! Good as new works every time on time and from half way down the road!
Old Mar 12, 2013 | 02:51 PM
  #37
balbs's Avatar
My Ride: BMW
Great posts! While my FM reception is still good, my remote range however has been significantly reduced from when I first got the car. Would it be the diversity antenna? I'm going to try cleaning the contacts first.
Old Mar 12, 2013 | 02:52 PM
  #38
balbs's Avatar
My Ride: BMW
BTW, should the battery be disconnected when doing this?
Old Mar 13, 2013 | 07:59 AM
  #39
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Both the radio and remote are in this amplifier, No need to disconnect battery.
Old Mar 13, 2013 | 08:06 AM
  #40
balbs's Avatar
My Ride: BMW
Thank you!
