dealer wants $500 to replace strut brace bracket
Can I do this myself? I am hearing a thud noise turning they said I need to get the strut bar brace bracket replaced. Does anyone have any experience doing it? Please help I have a 05 545
strut brace is what the dealer call it. The part I am talking about is the bar that goes form one strut to the other and it help to not let the body twist too much. I have searched and searhed and cant find the parts cauld somone please giude me to the right place.
My Ride: 05 545/6
I replaced all the bolts on mine because most of them had been stripped by some mechanic at some point in the past and they couldn't be tightened sufficiently. Took care of my thud problem. If you truly need to replace the whole bar it only involves removing the plastic covers in the area and removing 6 screws (two on each strut tower and two on the firewall)
My Ride: BMW
Save the $500 for other mods and PM members pinguhk, tonymac, and pjinca. They started individual threads when they installed aftermarket braces on their cars. Or are you referring to the anti-roll sway bar?
My Ride: 2006 BMW 550i
my guess is your front stabilizer end links are worn. the bar itself is a non-wear item....unless it got twisted or damaged somehow.
The dealer called it (replace strut brace bracket or strut tower brace it is the car that goes form one stut to the other and also conects to the fire wall. I have done a million searches and cant find a strut tower brace for 2005 545i.
