Coding 2009 E60: NCSExpert missing CAPPL module
Old 03-01-2011, 02:47 PM
nuclei's Avatar
Hi, I am a newbie just started coding yesterday,
I installed NCSExpert 3.1.0 and it works fine with reading/writing ECU modules except the fact that CAPPL is missing.
When I press F4 or click "Process ECU", it lists up many modules but there's simply no CAPPL module.
I could find a few variables like "MDrive" in CIC module instead though.
I am typically interested in VIDEO_DENY_C0B and LEGAL_DISCL can't find them in other modules.
Can anybody tell me where I should look at instead,
Or is there any way like updating daten files to v40?
Best regards,
Old 03-01-2011, 02:50 PM
BlaSTiWi's Avatar
Do you have Navigation?
Old 03-01-2011, 04:38 PM
nuclei's Avatar
Yes, I have navigation and I don't have MASK module either.
Actually I tried to read every other module but couldn't find some variables supposed to be in CAPPL like LEGAL_DISCL/VIDEO..C0B,
Is this because I am using outdated daten files or the car has newer ECU?
Old 03-01-2011, 05:18 PM
NoQuarter's Avatar
Engine: N54
For 2009 I think you have CIC not CCC.
Old 03-01-2011, 05:57 PM
BlaSTiWi's Avatar
Yeah seems to be outdated... you may need to update your daten files ...
Old 03-01-2011, 06:45 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
That is correct, 2009 will have CIC and not CAPPL. I just coded one two weeks ago.
Old 03-02-2011, 04:47 AM
nuclei's Avatar
Sorry to bother you again, perhaps I'm asking stupid questions but; then is it possible to code "VIDEO WHILE DRIVING" and "KILL THE LEGAL MESSAGE" with newer CIC module?
Old 03-02-2011, 05:42 AM
BlaSTiWi's Avatar
I think in your case it should be within the CIC module 'cuz car equiped w/ Navi will only have CAPPL module and one w/o Navi will only have MASK module.
Mine in the MASK module since I don't have Navi and got the DISCLAIMER turned off.
Try to read the CIC module and post up the trace (.TRC) file.
Old 03-02-2011, 06:20 AM
nuclei's Avatar
Thanks, I attached the trace file from reading CIC module, not modified.
File Type: txt
Old 03-02-2011, 08:06 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Yes, you can disable the disclaimer, however, the video while driving entries are very different for the new CIC's, so that I haven't figured out yet.
Quick Reply: Coding 2009 E60: NCSExpert missing CAPPL module
