Changing from Pre Lci Lights to Lci Lights
Old Feb 1, 2025 | 10:52 AM
  #41
gmcclintock's Avatar
My Ride: 09 F02 & 07 e60
Hold on you moved the pins and used a retrofit cable. It's either one or the other from my understanding
First of all, thanks very much for responding.
What I did was try it first swapping the pins and only one of the bulbs lit up - the outer most bulb on the right side light assembly.
When I put it back to it's original position I get the state I'm currently in - inner circle only
I must emphasize that I did 2 pin moves at the LM2 module (can't remember which pins as I completed this almost a year ago)
Thanks again
Beemer
33
Jan 14, 2019 05:13 AM
BMW565
Nov 6, 2017 06:03 PM
bbbamboo
Sep 17, 2017 04:33 PM
rizwan1377
Apr 5, 2015 05:22 PM
