Changing the orange LED to white LED on the cluster to look like M5 or
#241
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
i have a question if i unpulg the battery my car after i will replug the baterry when the jobe is finished i have to tap my code? i heard something about a code to enter is that true?
#242
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
#244
My Ride: 530i M Sport 2005
hi great post and mod. i have changed my needles to red and also changed my LCD back light LEDS to white, give the LCD a blue look with white TEXT looks ace. im also changing my interior LEDS to white i have noly got the door window switch to do.
#245
Engine: N54
- deleted - wrong thread
#247
Where did you get that background to RPM where is diesel scale and ///M badge?
#248
My question was, SMD-LEDs that I have to use to change the lighting in my E92 2007?
What characteristics should the PLCC-2:
Voltage, current, luminous intensity?
cris_f
What you put leds?
#250
My Ride: 530i
ricky1329,
My link
Do these leds will serve for an E92 2007?
Does the current is too high?
Thanks and regards.
My link
Thanks and regards.
