Changed my bulbs
#41
My Ride: 2004 Silver Gray 545i, Sport, Navigation, Steptronic, PDC, Windowshade, Bluetooth Paired with Treo 650, Huper Optik tint, Euro reflectors, Poplar Wood Gear Shift, Poplar Wood Console Cover
Great! Let us know what you come up with as I want to do exactly what you are attempting.
#42
Site Founders
Originally Posted by Hamann5' post='219251' date='Jan 4 2006, 05:24 PM
Dude theres somehting that I'm not under standing here.. the parking lights (angel Eyes) are run but 1 bulb on each side not 2.. the socket holder shown previosuly only hold one Bulb how is it that you have 2 bulbs on each side? Next question the bulbs you have how did you install then to the H6W format? as i see form the pics these bulbs are flat on the end where ass the stock Parking lights are rounded and in a H6W/BA9 format????
The halogen headlamp E60s use W5W wedge (flat) base lamps for the angel eyes; 1 per side, for a total of 2.
The xenon headlamp E60s use a lamp assembly with a captive Ba9 bayonet base lamp for the angel eyes; 1 per side, for a total of 2.
#43
I've done a similar mod to an E Class Merc and a Land Rover with great results. I'm very happy with these bulbs and a couple of years- in they are performing as well as day one. Sames goes for Phillips Silvervision turn signal bulbs.
#44
My Ride: Current - 330 Sport Topaz Blue, Grey Leather, HK HIFI...lost interest!!
Waiting for - 535d Sport, Silver Grey, Foldy Mirrors, 172 19",Logic7,Pro Radio,Through load,Heated Front Seats,High Gloss shadowline,Black Maple,Headlight wash,Sun Protection Glass.
[/quote]
Hi Das, I'm looking at your diagrames of the exploded head light units. The thing thats got be surprised is to see that the none Bi xenon (the hologen)which uses the W5W push in bulbs like the one in my earlier photo as Angel Eye/Side lamps show only one. I can confirm that I changed two W5W lamps per side, i have all four of the old lamps infront of me.
#45
Model Year: 2015
Engine: N55
Just ordered some from here
http://www.autobulbsdirect.co.uk/product.p...&cat=256&page=1
?23.99 per pair, plus free whiter bulbs for parking lights for orders over ?15.
Osram Supersilver came out best on test.
http://www.autoexpress.co.uk/product_test/?id=61032
TIP - order one pair of H7's on two different days to get two pairs of sidelight bulbs. no postage gharges in UK.
#46
Site Founders
I even checked the E60 535d right-hand drive model, just to see if there was any difference:
http://www.realoem.com/bmw/showparts.do?mo...798&hg=63&fg=05
Where were the extra wedge bulbs? Are they all in the same kind of socket? Do you have to take off the round covers on the headlamp assembly to get at them? Did you also replace the sidemarker lights (on the fender of the car behind the front wheelwell)?
#47
[/quote]
Das, the W5W lamps are in individual push in sockets behind the covers shown in the pics..detail doesnt actually go to the level of the harness, just shows the covers, one on, one off. Didnt change any other lamps, the only others are fog lamps which are fitted in the front under the headlamps.
![Changed my bulbs-blue_lamps_019.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/13903d1482363732t-changed-my-bulbs-blue_lamps_019.jpg)
![Changed my bulbs-blue_lamps_020.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/13904d1482363732t-changed-my-bulbs-blue_lamps_020.jpg)
#49
My Ride: Booked: E70n X5 40d M. Carbonblack, oyster, comfortseats, Nav Pro, Active Drive, Panoramic, Hifi PRO DSP, HUD, Alutrim, Satin ext, gloss rails, towconnector, elctric lid, alarm and more.
FS: E61 535D -06, Activesteering, Comfort seats, Hifi, M-steeringwheel, PDC, Rails, Tinted windows, Folding mirrors, Towconnector, Alu trims, Panoramic roof, ISO FIX, SonyEricsson BT-HF, 124 wheels, Alarm, Electric lid, Aburn interior, Xenons, Silvergrey and the crappy cupholders!!!
Originally Posted by das' post='219255' date='Jan 5 2006, 12:31 AM
I've been doing some research on the best ways to easily upgrade the angel eyes on E60s equipped with xenon headlamps.
E60s equipped with halogen headlamps use a W5W mini-wedge base lamp for the angel eyes. This lamp is a fairly typical automotive lamp, and is easily replaceable. There are also "bright white" offerings in bulbs of this type, as is seen in mixterk's installation.
However, E60s equipped with xenon headlamps use a lamp assembly that includes a captive mini-bayonet Ba9 base lamp, which looks like this:
![](http://forums.e60.net/uploads/post-1-1136160099.png)
Unfortunately, the lamp won't come out unless the assembly is taken apart, as is shown here:
![](http://forums.e60.net/uploads/post-1-1136160149.png)
There are a couple things I'd like to try:
1. An LED retrofit
Using the BF304-0CW-014B 4-LED white LED lamp shown here:
Attachment 13875 Attachment 13876
...along with a Luxeon LED collimator:
Attachment 13877
There are a few things that could go wrong here:
- It could be far too dim. This LED Ba9 retrofit, the brightest I've been able to find, has a light output of 1600 mcd (1.6 candela or 1.6 lumens). The existing 10W incandescent bulb it's replacing has a light output of 16 lumens, an order of magnitude difference. However, the nature of LED light combined with the collimator might produce acceptable results.
- The collimator, needed to effectively route light into the lightguides, might not fit in the current reflector.
- More modifications might be necessary, making it a more difficult DIY.
2. I have found higher powered, AND colored versions of the mini-bayonet lamp:
For example, there are clear, amber, green, and blue 23W bulbs of the correct type here (the original lamp is 10W):
http://easyparts.nl/showarticles.php...path=0-742-762
Osram Sylvania also makes a 20W variant of this bulb:
http://www.sylvaniaautocatalog.com/new_syl....asp?BatchId=29
Potential problems:
- The 23W blue bulb is promising, but the supplier does not sell outside of Europe.
- The blue bulb, combined with the effects of the lightguide, might get the rings to become very close to matching xenon headlamps. On the other hand, they may be far too blue.
- There may be problems with heat.
- Even a 23W clear bulb may not be much brighter: I tried going from a 10W -> 20W angel eye lamp (in fact, it was the same bulb) on my E39, with no discernible difference in brightness. This may be because the lightguide can only efficiently transport so much light, and an increase at the source doesn't necessarily correspond to an increase in the appearance in brightness of the rings.
In any case, I'm thinking about doing this stuff over the coming weeks, and I'll definitely keep people posted as to how it turns out.
1. An LED retrofit
Attachment 13877
Potential problems:
#50
I took this up with my dealer.
Do have the Xenon (bi-level) head lights and they are great.
I asked about getting the Angel Eyes and the inner H7 assist
high-beams and the fog lamps to 4600 - 4700 Kelvin lamps.
I should get I answer early next week.
