CD drive ate disk
Old Dec 4, 2008 | 05:49 AM
roadsterE61's Avatar
hello there,
my cd drive in the center console above the nav dvd drive 'ate' a cd...
I am sure that there is a disk in the drive (I can not insert another one)
only the IDrive says there is no disk in the drive and will therefore not eject the disk
is there any way to trigger a manual eject without hitting the cd drive with a jackhammer?
car is a 2004 E61.
thanks.
Tom.
Old Dec 8, 2008 | 11:51 PM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Originally Posted by roadsterE61' post='737693' date='Dec 4 2008, 03:49 PM
hello there,
car is a 2004 E61.
thanks.
Tom.
Hi Tom
Please try this before you take the "jackhammer" in use
Ig. key i pos. 1 , then press volum botten and both eject botten's at the same time for at least 20 sec. It should reset the M-ASK and at the same time eject any CD/DVD that might be in the CD/DVD-drive's.
If that fails close all doors , open trunk , take a key/screewdriver etc. and activate the trunk-lock ( car thinks that the trunk is closed ),now WAIT for ca. 30 minuts ( to the car have powered down ) then disconect the -(ground) pol. on the battery , wait for at least 15 minuts ( better20 than 14 minuts ) , now conect the - pol on the battery again , and then strigth away push the eject botton on the M-ASK.
Hope this solwe your problem , so that yor "jackhammer" not have to come in aktion
TexaZ3
May 6, 2015 09:54 AM
riches
Apr 20, 2015 05:08 PM
jckrauskopf
Feb 25, 2004 10:42 AM
jojo
Feb 21, 2004 12:00 AM
bankerboy
Jan 26, 2004 10:08 AM
