CD changer help
Since I am not a big Ipod user, had two different models and never used them. I'm looking to install a cd changer, my e60 has the cd changer prep option.
2004 525i
Can I use any cd changer from any year e60. What part # cd changer should I be looking for?
What parts are exactly needed to install it?
So far this is what I found:
1. cd changer
2. bracket
3. sheet metal screws
4. Optical fiber cable
anything else?
I will install it and then take it to the dealer to activate it.
2004 525i
1. cd changer
2. bracket
anything else?
Originally Posted by JetBlack5OC' post='450642' date='Jul 21 2007, 09:32 PM
Anyone? I know this may not be the most exciting topic, but any info out there?
If your car is CD prep'd you shouldnt need the fibre optic & power cables - they should be behind the glovebox.
You will need the CDC, bracket & screws - any E60, 61, 63, 64 CDC will fit.
- But, if you install it the dealer will have to remove to retrofit code your car... If it's installed, when the car is connected to the network the unidentified CDC will cause a small issue, hence it will have to be removed / bypassed prior to coding.
hope this helps...
Jetblack, i too am looking to add a cd changer and i have the same questions as you do! hopefully the e60 community can help us out.
lastly, where did you purchase you cd changer from?
Originally Posted by WHIZZKID' post='450930' date='Jul 22 2007, 01:07 PM
Hi,
hope this helps...![Confused](https://5series.net/forums/images/smilies/confused.gif)
hope this helps...
My Ride: 2004 645 Ci, Individual Stratusgrey Metallic with individual grey leather
Individual Stratos metallic, Shadow line, Black Individual leather, 19'' ellisoid, Panorama sunroof, PDC, Dynamic drive, Adaptive steering, Adaptive headlights, Voice control, Logic 7, Prof sat nav, BT phone, TV, Heated Sport seats, Ski sac, light pakket, CD-changer.
Mods (so far): iPod interface, K&N Airfilter.
If anyone interested: I have a CD changer laying around, I replaced it for a Ipod module. I am willing to sell.
Originally Posted by WHIZZKID' post='451804' date='Jul 25 2007, 08:31 AM
Approx 3 Hours labour...
I am in the same situation. Hopefully when I go to the dealer to get my CIP update, they'll include activation at no cost.
AirlinePilot
13
05-20-2024 05:56 AM
Vman33
03-14-2022 04:43 AM
Wonky
04-12-2016 08:15 PM
