Car Coding
#271
Actually you can do this with NCSexpert if you have the LM2. But you will have to do both head and tail lights and buy and install a cable from BMW.
#272
Engine: N54
#273
Model Year: 2005
Engine: 545i
Quick question
I want to add something to the FA (VO) list (for the first time).
Do I load the normal PSW FSW MAN profile or expertmode profile ?
any other tips/warnings?
#276
Model Year: 2005
Engine: 545i
OK, so added SA616 (online) to the FA list and activated :
CAPPL
ONLINE
aktiv
ONLINE_DISABLE_CONTENT
content_enable
ONLINE_DISABLE_VMAX
standard
SIM
aktiv
ONLINE_CALLSTRATEGY
use_csd_paketdata
Result is partial success - I'm not sure if ONLINE is available in Holland but I can't get past the "accept" button. When i press it I get this message: tel not available - although my cell phone is clearly connected.
![Car Coding-ccc-001-1280x768.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/116924d1482365907t-car-coding-ccc-001-1280x768.jpg)
![Car Coding-ccc-002-1280x768.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/116925d1482365907t-car-coding-ccc-002-1280x768.jpg)
Aside from that - how does one initialize BMW Assist?
![Car Coding-ccc-003-1280x768.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/116926d1482365907t-car-coding-ccc-003-1280x768.jpg)
<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">
CAPPL
ONLINE
aktiv
content_enable
ONLINE_DISABLE_VMAX
standard
SIM
aktiv
ONLINE_CALLSTRATEGY
use_csd_paketdata
#277
You need to have a valid assist and connected drive account first, heres a litle food for thought, I disabled my online and then retrofitted it with progman and it added SA 616 plus SA613 internet services to the vehicle order and coded both CAPPL and TCU.
#278
Model Year: 2005
Engine: 545i
I didn't check, but since I added 613 and 616 should I see a TCU module in NCS now?
#279
What blue tooth have u got?, basic (MULF) or bluetooth and telematics (TCU). mine has worked from the day i discovered it, theres a post about it on here some where. I just wanted to what the official retrofit did.
#280
Model Year: 2005
Engine: 545i
According to my list (before adding 613 616 to FA):
ALC = adaptive headlight control unit
AMPT = hifi amp logic7
BFS =
CAPPL= CCC aplications
CAS = car access system
CAUDI= CCC audio controller
CGATE CCC gateway/MOST
CHOST= CCC host
CID = central information display
TCUM = Bluetooth
DSC = dynamic stability control
DWAI = infared detector for alarm system
DWAS = anti theft alarm system?
EGS = electronic transmission control
FAS =
HUD = heads up display
IHKA = intergrated automatic heating and airco
KBM = body, basic module
KOMBI= instrument cluster
LMA = light module
LSMC = steering column memory?
MPM = micro-power module
MSHD =
MULF = basic bluetooth handsfree system
PDC = parking distance control
RLS = rain-light sensor
RSMC =
SBSL = b-pillar satellite left
SBSR = b-pillar satellite right
SFZ = vehicule centre satellite
SGM = safety and gateway module
SZL = steering column switch cluster
SZM = centre console switch cluster
TMBT = door module (front or rear)
TMFT = door module (front or rear)
I don't see TCU - what's that?
