Car Coding
#151
Engine: N54
The VA_ADAPTIVEHEADLIGHT adds "Adaptive Headlamp" to the iDrive menu with options for Off, Sport and Comfort. I drove the car around this evening and I don't see any difference with any of the settings. "Off" doesn;t even turn the adaptive function off.
I will recode my LMA to remove that menu option.:thumbsdown:
Also...
My LMA would not take the Bi-Xenon flash to pass option. The coding session kept erroring everytime I tried to change that one.:thumbsdown:
I did get the option to keep my fogs on with my high beams.
Their are quite a few references to DRL's and Tagfahrlicht in the trace files. Maybe something is in there for the Angel Eyes. Are they referred to as corona also?
Also...
#152
Engine: N54
Anyone have the code option for "Corner Delete"? This turns off the amber parking lights so the angle eyes stand out better but the amber lights still flash for turn signals.
#153
[U.S. indicators with side turn indicators on parking lights or headlights]
Control unit: LMA
DRL_TFL_BLK_V_GED
nicht_aktiv -> active
PWM_SIDEMARKER_BLK_V
wert_01 = off
wert_02 = light
wert_03 = dark
[Side marker lights with daytime running lights activated (only LCI)]
Control unit: LMA
SL_V_MIT_TFL
active
#154
Engine: N54
#155
No probs...We should really start a new thread with all the verified coding and explanations only in it as a on-line resource... keep the testing and questions in a separate thread? (Think someone may have already mentioned it)
#156
Engine: N54
That's what I had in mind a few threads back. I'll create a new one now and try and get enough key words in it so it will be found in searches.
#158
Hello everyone, i saw that here most of you have 5 series, but i hope not to upset you becouse i have a 3 series and i want to find out something. I found very useful your topic, i tried some and i coud do it, now i have DIGITAL SPEEDOMETER on my screen, but i can't do WELCOME LIGHT. I saw that the module on 5 series is COMBIATION or something like this. Can you tell me in what module can i find WELCOME LIGHT on 3 series? Or where can i find more coding options for 3 series. Thank you.
#159
Engine: N54
The Combination module on ours is called "KOMBI".
Good luck!
#160
I would help If I could. I don't know the modules or if the options in the modules have the same name as ours. Something I found useful is to read and save the trace file for all the modules into a folder on the PC and make sure that indexing is enabled for that folder. When I do a search for say "Welcome Light" all the text files that contain that key word show up in the results.
Good luck!
Good luck!
I saw that you use LMA module for welcome_light, it can be FRM for e90 ?
I find that COMBINATION module is KOMBI on e90 and there i made activation for digital speedometer.
Maybe i can get help with this welcome light to.
Thank you.
P.S. Someone can tel me where can i find a new version of INMPA or NCS ? Or it can upload, please tel me and i give you an ftp where to be uploaded.
