Car Coding
#101
Hmmm I think my worry is that my LMA currently doesn't have the welcome light nicht active / active option, so even if I update, I'm not sure it will allow the function to work, as SAS seems to have an updated LMA module and its not doing the lights as expected when the options enabled..
Worth a shot I guess but I think you need the LM2 module to get these working via coding..
#102
yes I guess LM2 it is. I had thought that I read that BenAnd had done some hack for the LMA itself but he has confirmed that he too put in an LM2 to get his LCI lights done.
#103
My Ride: 520i ('04)
Car was updated (with ISTAp v2.38) by the BMW dealer in 09/2010, the only new option added was DRL's (low beam without rear lights) and MP3 enabled, where other dealers sayed it was impossible to do with 2003 M-ASK moddels.
#105
My Ride: 520i ('04)
But as you metioned before
#107
My Ride: 2007 E60 535d M Sport
Has anyone done the LCI lights conversion (pre-LCI Bixenon AHL to LCI Bixenon AHL) and coded it themselves using NCS? What needs modifying and in what modules?
My car is build date 12/06 so has the later LCM, and the AHL modules on the headlights end in part number 312.
All the wiring is sorted, including the 2 wires from the back of the car to the LCM and swapping the 2 wires already on the LCM plug.
Thanks.
Thanks.
#108
Engine: N54
#109
Engine: N54
My Welcome Lights are working
The auto setting on the light switch did the trick. The lights are at the defaults right now - so I get the angle eyes, corner lights and plate lights fade in and out for about 30sec when the car is unlocked or the door opened.
#110
Thanks.
Thanks.
