Car Coding
#91
Looks like you need to have the 2nd gen LMA
![Getlost](https://5series.net/forums/images/smilies/imported/getlost.gif)
if anyone with a pre 06 gets there lma updated and gets this to work let us know, I may update my lma to see but it would be interesting to know if any pre 06 owners have this coded and working
#92
I get the same, can see the option but not select it in drive, I see your car is an 04, so I guess it doesn't work even if you activate it in LMA.
or have it updated to see if it will work.
i have a pre 06 and i have the welcome lights enabled on the CCC but its not there for me to select on the LMA, because when i select it on the light options in the CCC it unticks itself.
so i guess i need to get the post 06 LCM and then code it to the car.....
#93
![](https://5series.net/forums/public/style_emoticons/default/confused.gif)
#94
My Ride: 520i ('04)
WELCOMELIGHT <==== the only entry that is showing after coding
nicht_aktiv -> activ
WL_AL = low beam <==== LMA doesn't accept these
nicht_aktiv / hart_einschalten
WL_BL = brake light
nicht_aktiv soft_einschalten / / hart_einschalten
WL_BLK_H = Left Rear
WL_BLK_V = front indicator
WL_FL = beam
WL_KZL = plate light
WL_NSL = rear fog lamp
WL_NSW = fog
WL_POL = position or the front parking light
WL_SL_1 = closing or parking light rear 1
WL_SL_2 = closing or parking lights, rear 2
WL_SM = Eyebrow
CKM is not even showing the options.
So LM2 (from 09/2006 and up, partsnr. 61359192641 or 61359203081) is needed!
#96
Tried to add to LMA:
WL_BL = brake light
WL_FL = beam
WL_NSW = fog
WL_SM = Eyebrow
WL_BL = brake light
WL_FL = beam
WL_NSW = fog
WL_SM = Eyebrow
Thanks for confirming SAS
![](https://5series.net/forums/public/style_emoticons/default/thumbsup.gif)
Hmm how much is the LM2 module
![](https://5series.net/forums/public/style_emoticons/default/getlost.gif)
#98
My Ride: 520i ('04)
#99
JAY according to the ETK around £336 including VAT add 2.5% after jan 1st![](https://5series.net/forums/public/style_emoticons/default/thumbsdown.gif)
Part no. 61 35 9 203 082.
It will need coding to your car as well.
#100
What about trying to update the LMA software to see if then accepts the new variables for the welcome lights.
