Calling for some one has NCS and LCI halogen lights
Engine: N54
I assume you did this by reading ECU, backing it up then writing a blank then -re-reading? Curious to see if there's another way or if I am misguided.
You don't even need to be connected to the car or even own the car or the ECU to make a default trace. Do a find for my post on it
You could generate the tracefile yourself. Just set the VO how you want it, load up expert mode, load up the KOMBI module, click "basic functions", highlight "GetNettodatafromCBD" and click ok. Then go back to "basicfunctions", click "GetFSWfromNettodat", point it to "NETTODAT.TRC" and save the file as whatever you want to call it. Now you have a default FSW_PSW for that car's VO.
Engine: N54
I won't be able to anything for the next several days. If you still need something done next week hit me up with a PM.
rackhacker9275
26
04-16-2015 08:13 AM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
