Is the on-board (navigation) screen backward compatible
Like the title says - just want to find out if a 2008 navigation screen is plug-n-play for my 2006.
All help is greatly appreciated
Banned
My Ride: A Car
01 AT-On-board monitor 8,8" FA. SVDO 1 09/2004 03/2007 65826981562 $1,367.13
01 AT-On-board monitor 8,8" FA. SVDO 1 09/2004 09/2008 65829118720 $1,367.13
01 AT-On-board monitor 8,8" 1 09/2004 11/2008 65829193757 $1,828.14
01 AT-On-board monitor 8,8" 1 09/2004 03/2009 65829193757 $1,828.14
01 AT-On-board monitor 8,8" FA. ALPINE 1 09/2004 03/2007 65826981560 $1,828.14
03 Socket housing 12 POL. 1 61138384550 $0.77
only in conjunction with
-- Terminal socket MQS ELA 0.2-0.5 MM˛ SN ? 61131393704 $0.23
-- Terminal socket MQS ELA 0.75 MM˛/SN ? 61138366260 $0.23
-- Covering cap 12 POL. 1 61138387206 $2.07
Socket housing is the same. I can say it's probably good.
Thanks John! Unfortunately the guy that I was gonna buy it from jacked the price two-fold after our initial convo, so I bailed. I don't blame him for wanting to get the money he wants for it - just can't stand it when people name one price and then ten minutes later say they want twice as much for it... thanks either way!
I had an 04' pre-nav wired but unfortunately no nav. I bought a brand new 2007 X5 professional screen for $150 took out my old 6" screen and retrofitted the black housing. The metal plug didn't fit as it had an edge of plastic i had to shave off.....but after shaving the little piece of plastic it fit perfect and worked with no issues. However, a problem did come up in programming because the computer did read it as a different part number the programming failed until they took one out of parts and hooked it up to finish the programming them put my screen back in.
My Ride: 05 545/6
if you already have nav, the LCI unit will work fine as a replacement. If you are trying to do the retrofit, it will only work if you go to an indy with an Autologic unit (or that guy doing the new 2010 retrofits on-line.) Like refaie1, I did the retrofit with an ebay monitor...and ended up having to swap it out at coding time because the BMW computer complained about it.
