Battery Registration and more....
My Ride: BMW E60 520i se genuine m sport kit,18" M6 Wheels, reverse camera, lcd headrests,dvd player, multimedia device
,black kidney grills
well when i googled INPA this is what i got LOL... "Institute for Nuclear and Particle Astrophysics (INPA) unites research in astrophysics - including solar neutrinos, cosmic rays, dark matter....etc etc
.....for some reason i dont think these guys have the software im after
NCS folder http://www.4shared.c...37f2mH/NCS.html password is INPA make sure you use capitols
if you download each file on its own theres no need to pay and register just hit the little green arrows at the end of the file name
i hope this helps
i hope this helps
i hope this helps
i hope this helps
www.4shared.com/dir/3U37f2mH/NCS.html try this one ive tried it and it works fine....you have to copy and paste it to your browser as if i make it into a proper link half of it gets changed for some reason
Post #10 http://www.bimmerfest.com/forums/sho...d.php?t=505694
Did you get INPA program up and running? Im going through the setup directions, It says i need to Run Instprob.exe but i cant find it anywhere in the downloads
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
Did you get INPA program up and running? Im going through the setup directions, It says i need to Run Instprob.exe but i cant find it anywhere in the downloads![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
http://cgi.ebay.com/...omotiveQ5fTools
Here is the cable. I ended up buying the entire package from that seller because INPA doesn't do much and many INPA's are floating around incomplete. I needed SSS specifically.
