Aux - Low sound from right side with Sirius module
I just installed a Sirius Stratus 6 in my 2005 530i. It is installed using the aux-in port in the glovebox. Left speaker sounds great, but right speaker is very low volume. Sound comes out of it, but it is very quiet.
I have previously used my iPod in the aux with no issues.
Any suggestions or fixes would be great.
Thank you.
Thank you.
My Ride: Present--'04 545i- Premium, Sport and Comfort Seat Packages; Aux Input Cable, Staggered RFT Tires, 65K miles as of 04/10, 6-Speed Manual, Active Headlights, L7 Audio, Auto Sunshades
Past--(FIRST CAR EVER OWNED)--1981 318i Euro Specs
Thank you.
Thank you.
How are you connecting the sirius to the aux input? If you are doing it through an aux cable, try putting the cable all the way in and then pulling it out just a little bit at a time. I mean very little at a time. This is a common problem I have with aux cables. Sometimes it just cant be pushed in all the way. Let me know how it works. Good luck.
It's connected to the BMW aux-in via the aux-out on the Sirius module. I'll try pulling it out a hair and see what happens.
Thanks.
Thanks.
