Anyone having moonroof retraction problems??
Old 02-07-2010, 06:36 PM
pauliehcfr's Avatar
just remove the top edge of the accordian pieces then gently slide the floating headliner forward to lock it back with the accordians. also spray some WD-40 into the tracks and slide the headliner back and forth a few times
Old 02-07-2010, 06:40 PM
rjcastr's Avatar
i havent closed it all the way since it wont close at all now. i will try to losen it up tomorrow and try again. i hope i can get it fixed and the stealership won't get me
Old 02-08-2010, 02:31 PM
pauliehcfr's Avatar
What does it do when you close it? is it still hitting the defelctor?
Old 02-08-2010, 04:39 PM
tarek307's Avatar
My Ride: 02" Porsche Carrera 911
Mine is now not pulling that bottom part cover open with it, i have to push it with my hand
Old 02-08-2010, 04:59 PM
pauliehcfr's Avatar
that is because it is not locked in to the accordian pieces. if you remove them, slide the headliner forward some (leave yourself room to put the pieces back in) then install the rear part of the accordian into its channel and then snap the front into place
Old 02-09-2010, 07:11 AM
rjcastr's Avatar
Thanks Paulie,
im not an expert at this, i took my car last night to a bmw mechanic that will be doing the harder to do maintenance work on my car like the fuel filter differential etc etc. he fixed that in a heart beat he actually removed the accordion pieces took the screws out lifted the glass out and put it back on tracks i actually helped him level it flat to the roof while he was putting the screws back on we tightened and waala 20 bucks tip well spent, BMW dealer said most likely would have to replace the whole thing because its broken hahahah! I hate STEALERSHIPS!
Old 02-10-2010, 08:51 AM
pauliehcfr's Avatar
Sorry about that. It seems like you did everything right though. $20 is a good price to pay for that.
Old 02-10-2010, 08:04 PM
rjcastr's Avatar
hes a real bmw mechanic so he knows what hes doing
he will be doing work on the side for me thats a good find, brakes for 150 rotors and pads is a deal
Old 02-10-2010, 09:00 PM
tarek307's Avatar
Whoa Paulie Walnuts, what are you talking about? accordians, locks, clips..lol, i have no idea about howto do any of this Thanks though!
Old 02-11-2010, 10:52 AM
rjcastr's Avatar
its all there, he's actually right, you just have to remove the accordion looking pieces i would remove everything realign the glass have someone hold it on the outisde and tighten from the inside.
if i had to do it all again i would know how.
thanks again paulie
audiophool
05-31-2015 08:20 AM
TexaZ3
05-06-2015 09:54 AM
JohanDC
05-03-2004 03:40 PM
bankerboyz
21
04-21-2004 11:10 AM
DO
01-14-2004 11:11 AM
Quick Reply: Anyone having moonroof retraction problems??
