AE Illumination when unlocking the car
#241
My Ride: BMW E60
Model Year: 2016
#245
My Ride: 525i
Mine is now starting to flickering since i but 4 leds bulbs in for the angel eyes. 1 diode should be enough for 4 led bulbs and 2 led strips ?
#246
My Ride: 525i
#247
My Ride: 525i
I just install 4 bulbs on mine AE, running fine without any error message. But when i tap to the foot light, it won't come on and the interior lights ( foot and dome ) wont' come on too. What the hell ?
I changed new diode but still the same.
Help
Help
#248
My Ride: bmw e60
on this project, i want to connect a relay who interrupt the power betwen footwell and AE but for that i need to find a wire who have 12v only when the ignition is in position 1
So where i find a 12v wire like accesories or radio?
#249
My Ride: 2004 E60 Titansilber Metallic
...tap the wires directly coming from the light module, they are the same wires, but at the other end...
According to WDS these are the interesting pin numbers we need:
Pin 2: Eyebrows (Left and right ones are connected to the same wire on pre-lci cars)
Pin 40: Right Angel Eye (Pre-LCI)
Pin 25: Left Angel Eye (Pre-LCI)
Pin 3: Left License plate light
Pin 49: Right License plate light
Pin 64: Left Tail Light
Pin 10: Right Tail Light
Pin 23: Rear Left Fog Light ---- You can wire a 12v to 5v ebay stepdown converter in between to make rear fogs light the same as when they are position lights.
Pin 67: Rear Right Fog Light /
Pins are numbered by rows in the light module white connector, but if you remove the white housing of the connector, they are all numbered individually.
My issue may be unique since I have the pre-LCI halogen setup with 4 bulbs for the angel eyes. Contrast that with the projectors that use a single bulb per side. The pins labeled here only light up the outer angel eyes for me.
Can someone with the proper computer setup access the WDS to find which pins on the LM light up the inner rings? Much appreciated, and it would help out anyone else with the same setup.
BYS2
03-30-2015 05:33 AM
