AC basic to AC high retrofit DIY rev.3
Old Jan 28, 2018 | 04:10 PM
  #141
Sasa Radisavljevic's Avatar
My Ride: BMW
I do not have a problem with the fan, I saw some members that they had a problem with the fan that they did it to the maximum, I did not have such a problem
everything worked okay
I have a problem when I return the keys to the minimum, it also blows hot air
Old Mar 24, 2018 | 02:56 AM
  #142
Piotr Bytniewski's Avatar
My Ride: BMW E60
Hello. I made this retrofit but have one question. What gives additional solar sensor? I already had one, it brightens clocks and new ac high panel in tunels etc. Whats the point in adding second one?
Old Mar 24, 2018 | 03:28 AM
  #143
Misterbish's Avatar
Banned
My Ride: E60 530D
The solar sensor you are talking about measures light so it knows when its getting dark to switch on the auto lights etc.
The solar sensor mentioned here detects the heat of the suns rays projected through the windscreen and adjusts the A/C to compensate
Old Jan 7, 2019 | 11:12 AM
  #144
darian81's Avatar
My Ride: bmw e60 530i lpg
hello together a happy new year I wish you together. I write with a translator that's why the sentences are. I have a question is the description of BLooD for conversion from old to new what I have on foto ??
Old Jan 7, 2019 | 11:53 AM
  #145
darian81's Avatar
Default Basic to lci Panels
description for that right ??? please i need help. I wanted to know if I have the problem afterwards with ventilator. I do not want him spinning fast.
Old Jan 8, 2019 | 02:12 AM
  #146
darian81's Avatar
translator does a lot wrong. I can take description of BLooD. for remodeling my picture. The fan rotates normally with it.
Old Nov 21, 2019 | 06:19 AM
  #147
Пламен Марков's Avatar
Probation Members
My Ride: BMW E60 530D manual
Ok. Onem ore with problem. Changed non LCI high IHKA to LCI high IHKA. Moded pin 21, updated software of the ihka with WINkfp and changed VIN to corect one, coded module to car VO list. Everithing works and looks perfect. Only one error - https://photos.app.goo.gl/JoJudNyU9MLd2KQ87
E720 message error (status solar sensor ... ) my solar sensor is in mid speaker grill, LCI one is in RLS sensor on the mirror. Any solution?
Old Feb 16, 2020 | 11:21 AM
  #148
V8d4eww's Avatar
My Ride: e60 pre lci 530d M-sport carbon black
Hi blood, sorry to bring this back from the dead.... Again. I have fitted pre lci high from pre lci basic. It all works but I just need coding. Is this something you could do for me, I amin essex as well (big place I know) but I don't mind travelling. Will the coding allow me to adjust vent positions as I can no longer adjust to feet etc.
Old Jun 8, 2020 | 08:45 AM
  #149
Dimi23's Avatar
My Ride: Bmw 530 E60
I have a problem with my climate, I followed the guide for conversion from base has high lci, but I have this problem as in the video how can I fix it?
Old May 13, 2021 | 04:40 PM
  #150
Ardit's Avatar
My Ride: Bmw e60 525d automatic
Originally Posted by dzwx
blue 26 pin connector (X1527)
PIN No. Description Colour Gauge
1 - Signal, LIN BUS Blower Motor Output Stage Blue/Red 0.5
2 – Supply, AUC Sensor White/Red 0.5
3 - Signal, AUC Sensor Grey/Brown 0.5
4 - Supply, Condensation(Fogging) Sensor Blue/Yellow 0.5
5 - Signal, Condensation(Fogging) Sensor Blue/Grey 0.5
6 - Signal, CAN Bus System High Black 0.5
7 - Signal, CAM Bus System Low Yellow 0.5
8 - Supply, Refrigerant Pressure Sensor Grey/Black 0.5
9 - Signal, Refrigerant Pressure Sensor Blue/Black 0.5
10 - ------------- ----
11 - ------------- ----
12 - ------------- ----
13 - ------------- ----
14 - Signal, Electric Auxiliary Heater White 0.35
15 - Signal, AC Compressor, Pulse Width Modulated Black/Green 0.75
16 - Signal, Water Valve Left Yellow/Brown 0.5
17 - Signal, Water Valve Right Yellow/Purple 0.5
18 - Signal, Auxiliary Water Pump Green 0.5
19 - Signal, Rear Window Defroster Grey/Black 0.35
20 - Signal, Washer Jets Heater Green/Black 0.5
21 - Signal, AC Compressor Control Valve White/Green 0.75
22 - Supply, Rear Compartment Potentiometer White/Green 0.5
23 - Signal, Rear Compartment Potentiometer White/Blue 0.5
24 - Signal, Ventilation Temperature Sensor Blue 0.5
25 - Ground, Control Panel Brown 0.5
26 - Ground, Rear Compartment Potentiometer White/Brown 0.5
hi can you help with ac compressor problem ?? thanks
