AC basic to AC high retrofit DIY re-write.
Tom_iL I need to revise the instructions again.
In order for you to use the left hand side temp control you will need to swap pin 1 to pin 2 (i got this wrong) but you will not need to change the pin (12) for the water valve, so long as it receives the signal from the panel I don`t think it matters which temp control is working.
My Ride: 520i ('04)
My Ride: 520d M Sport
Titanium Silver
Retro fit's -
Professional Sat Nav
Footwell Lights
BMW Bluetooth
LCI Halogens with HID
Going to go for this, so i am looking at buying all the parts can i ask a couple of questions, do i need a specific AC Controller for my 2006 car or will any High Controller work.
Also is there a how to code section anywhere if i buy NCSexpert and the cable or can somneone post how to code the AE once installed.
sorry to ask stupid questions.. and thank you for the info on this absolutly brilliant.
My Ride: BMW 525dA 2007 pre-LCI.
I have same question,
RealOEM says there are no more then 8 different ones. The 64119122398 beeing the latest one, which would normally be put in my car as its from 01/2007.
I wonder what the differences are. Anyone a clue ? would a 64116946981 be any good as its one of the older ones ?
This is what RealOEM gives :
01 Control unit, automatic air cond., High 1 03/2004 64116944020 ENDED
01 Control unit, automatic air cond., High 1 03/2004 64116944024 ENDED
01 Control unit, automatic air cond., High 1 09/2004 64116946981 ENDED
01 Control unit, automatic air cond., High 1 03/2005 64116956827 ENDED
01 Control unit, automatic air cond., High 1 09/2005 64116950634 ENDED
01 Control unit, automatic air cond., High 1 03/2006 64116978435 ENDED
01 Control unit, automatic air cond., High 1 09/2006 64116988504 ENDED
01 Control unit, automatic air cond., High 1 03/2007 64119122398
Titanium Silver
Retro fit's -
Footwell Lights
BMW Bluetooth
Got to say big thanks to Blood,
almost finished the AC High today just some coding to finish it, i used a 64116956827 controller on my 2006 and it works fine.
think i might add the condensation sensor next.
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Do you need the pin outs for the condensation sensor?, did you do the solar sensor?
Titanium Silver
Retro fit's -
Footwell Lights
BMW Bluetooth
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Blood
Once this is fitted do you lose any controls that you had before? Also which new features does it give
Also what sort of price does the connectors come up to and solar sensor is this a must or can you do without it
X1527 (blue) Sensor
4-------------------3
5-------------------2
