530i Steering Wheel Trim Replacement
My Ride: 2004 530I Black/Black, Premium/Sport, Navigation
2005 545I Silver/Black, Premium/Sport, Logic 7, Navigation
Hi, Do you have the part number for those pieces?
Tks!
Adam,
I paid $40 (discount price) from Circle BMW in NJ. The list price was $50.
Ching-Ho Cheng
Tks!
Originally Posted by lcc014' date='May 1 2005, 05:25 PM
[quote name='acribb' date='May 1 2005, 04:46 PM']Thanks for the info.? Good stuff.
How much did you get the part for, out of curiousity?
[snapback]122637[/snapback]
Ching-Ho Cheng
[snapback]122651[/snapback]
[/quote]
WoW Good job there
Yeah we want the part number..
My Ride: E60 530i
Engine: M54
Originally Posted by soc_fans' date='May 16 2005, 12:36 AM
WoW Good job there?
Yeah we want the part number..?
[snapback]129084[/snapback]
Ching-Ho Cheng
Big problem. I have followed the instruction and now all the setting were reset. Have to take my car back to dealer. The active steering wheel Mal function warning is also ON. Perhaps I shouldn't disconnect the battery.
There's a warning on the service menu showing that the battery were disconnected and the car need to set the date too.
All the scheduling maintanance log is in warning mode too.
My Ride: E60 530i
Engine: M54
Originally Posted by the88saint' date='May 17 2005, 01:32 AM
Big problem. I have followed the instruction and now all the setting were reset. Have to take my car back to dealer. The active steering wheel Mal function warning is also ON.? Perhaps I shouldn't disconnect the battery.
[snapback]129518[/snapback]
Maybe, Hobi can shed some light on the maintanence log issue. I had no problem with that too.
Ching-Ho Cheng
Active steering warning went off this morning. There's a record on the system info saying the need to update the time due to disconnected battery, i tried to update the date many time and it keep asking me for it. The date info do shows up on the dash console, but not on the idrove screen.
Could you tell me how can i reach Hobi? And in case i need to take the car back to dealership, maybe i should put the black trim back.
My Ride: 2005 MY 545i Sport Saloon. 2006 MY Alpina B3S Convertible. 2006 MY Brabus Smart 42 Cabrio. 2006 MY AM DB9 Coupe.
I just PMed you.
the active steering warning light is EASY to reset. You have to start your car, then turn the steering wheel ALL THE WAY ROUND TO THE LEFT as far as it goes, hold there for a second or two, then ALL TEH WAY ROUND TO THE RIGHT as far as it goes, hold there for a second or two, then centre the wheel and start driving at about 30 MPH around your block. Switch off the engine and restart the car and drive, the light will go out.
We did this on Kigerka's car when he changed his SMG levers (battery disconnected).
The warning light is there to tell you that the steering angle sensor in the steering column unit needs to be programmed with the END points of the steering rack. the above procedure is as documented by BMW in one of their Service Info guides.
Are you REALLY setting the time and date properly??? Because it only asks you once! Once you do it and confirm it, that's it...
Don't worrk about the black trim etc.. my PM tells you what to say etc..
All the Best
Hobi
All the Best
Hobi
