2 question about headlight
1. I'd like to check with you, guys, whether to disconnect 2 wire connectors at the back of the headlight I just have to pull them out or not that simple? I was trying to do it, but I was afraid I would break something, because they didn't want to pull out.
2. Can anyone tell me part number or size of bolts with the number 1?
![](https://i565.photobucket.com/albums/ss100/sir777/headlight.jpg)
Thanks!
Thanks!
Originally Posted by jgulli' post='886171' date='May 21 2009, 11:12 PM
If they're the H7 you just pull the bulb out, not sure about the size of the bolts, but had the right tips in my standard socket set.
Good Luck
Good Luck
I think they are Torx bit size T30 ... or the #2 ... hmmm
are the #1 for adjusting the vertical/horizontal alignment?
Thanks!
Thanks!
