WHAT IS OXIDATION
Most modern car finishes consist of a base coating that contains the color, topped with a protective clear coat that is designed to keep the pigmented paint from oxidizing. This outer clear coat adds UV protection that helps prevent the sun's rays from drying out the base paint. Oxidation was an obvious problem ten years ago because you quickly saw the color fade. Now that the outer layer is usually clear, oxidation is less obvious, yet it still occurs. The sun dries out top paint layers and natural oils are lost. If these oils aren't replaced, the paint oxidizes and the surface gradually becomes duller and duller.
Even more than yesterday's paints, today's clear coat finishes look faded whenever the surface becomes contaminated by airborne pollution, acid rain, industrial fallout, and countless other factors. If the contamination isn't removed frequently, it reduces the reflective quality of the finish until it looks dull and lifeless. If the contamination is left on the car for some time, it can begin to etch into the thin clear coat paint layer and expose the base coat to direct UV rays and even greater damage. Once the clear coat protection is gone, the car usually requires costly repainting.
Autopia-CarCare
Detailing Forum
04-21-2014 07:14 AM
Rudy
01-08-2008 02:17 AM
