feels like sand
Old 11-27-2007, 11:33 AM
spedridr's Avatar
After I washed my car, if you take the back side of your finger and run it along the top of your moniter thats how my roof and hood felt the lower parts of the doors are nice and smooth and feel like a waxed car should, but everything else does not feel good. I tried using a couple differnet typs of wax's but they all had the same result, the paint still felt the same. I was doing some research and it looks like I should find clay bar and use it? should that take care of the problem? any sugestions?
Old 11-27-2007, 02:41 PM
Westcoast M5's Avatar
Yup, clay it and it will feel like glass.
Old 11-27-2007, 03:19 PM
KnIgHtCoM's Avatar
+1 Sounds like you need a good claying.
Old 11-28-2007, 12:39 PM
dbm
dbm's Avatar
How many times clay in a year?
Old 11-28-2007, 01:03 PM
westcoast550's Avatar
I clayed my car a couple of months ago , it is so simple and easy to do, the only trick is to keep the clay clean and the surface well lubricated,as Westcoast M5 says it will feel smooth as glass,
Good Luck !
PS check out the detaling section here for lots of others inputs as well
Old 11-29-2007, 11:39 AM
spedridr's Avatar
thanks guys! i'll be doing it tonight after I get off work, I cant wait!
Old 11-29-2007, 11:40 AM
spedridr's Avatar
Can I wax it after I clay it? Or is that overkill?
Old 11-29-2007, 12:05 PM
Absolutely , do it right away ! This protects all the work you just did. Check out the Mequiars web site for their multi step method of detailing.
Cheers
Old 12-10-2007, 05:56 AM
HotLap's Avatar
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
Yes, you need to wax it right after claying as the clay bar removes all wax, etc. Used properly, the clay bar will not harm your clear coat as it is "lifting" embedded contaminats out of the clear coat, which is a softer paint than the color coat (for durability). You will not believe how smooth your car will be after a clay coat. I generally clay the entire car once per year, then do a touch up clay on the horizontal surfaces (trunk, hood, top bumper surfaces, etc.) when necessary.
Old 12-28-2007, 09:02 PM
Bimmer32's Avatar
What's the difference between polishing and claying? Can you polish with claying and still remove the contaminants?
Quick Reply: feels like sand
