Extended Maintenance Program
My Ride: BMW 550i Sapphire Black on Black.
Is it worth it and how much did you guys pay for it. My maintenance warranty is up and am thinking about buying it
Search. I think I saw around $1800, but if it is worth it depends on how much you drive and how much you will use it. If you are a low mileage driver, you may only get two oil changes and a brake fluid change and it is too much. If you put a lot of miles on your car, then you may get 3-4 oil changes, a brake fluid change, brake pads and rotors changed - but it ends up about what you would have paid an independent mechanic to do the same work. I believe the clutch is covered if you have a manual transmission, so that is something to consider as well. If you need a new clutch, that would certainly make it worth the price of admission.
I thought about mods but I think getting a M5 will be cheaper. Now to convince the pregnant wife that a m5 is a good family car
My Ride: 2008 535xi
My Ride: 2008 535xi
Dead sure it was extended maintenance. Just went in for a 60K checkup. The dealer may be making a commission over the msrp, who knows. Also I was at 58K miles, I think the price is different if you are under 50K. Doesn't really matter now.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
Bogdan7
09-23-2015 11:40 AM
