Is it worth it and how much did you guys pay for it. My maintenance warranty is up and am thinking about buying it
Search. I think I saw around $1800, but if it is worth it depends on how much you drive and how much you will use it. If you are a low mileage driver, you may only get two oil changes and a brake fluid change and it is too much. If you put a lot of miles on your car, then you may get 3-4 oil changes, a brake fluid change, brake pads and rotors changed - but it ends up about what you would have paid an independent mechanic to do the same work. I believe the clutch is covered if you have a manual transmission, so that is something to consider as well. If you need a new clutch, that would certainly make it worth the price of admission.
save your money for mods!!!!!!!!
I thought about mods but I think getting a M5 will be cheaper. Now to convince the pregnant wife that a m5 is a good family car :twoup:
Originally Posted by e60winbutton
(Post 1167311)
Originally Posted by sahiljain22
(Post 1168966)
I just got mine for 2300 for my '08 535xi w/ 58K miles. Shopped around a lot but just couldn't find someone lower. Im in MA, if that matters.
Originally Posted by 325/528
(Post 1169007)
Surely that is an extended warranty and not extended maintenance. I think the msrp is $2199 for extended maintenance.
