Treo 700W bluetooth compatability
I just got the latest from one of my coworkers regarding the bluetooth compatability with the BMW bluetooth car kit (I have a 2005 BMW 545i, 19.x.x software). I work at VerizonBusiness which is totally separate from VerizonWireless, but I was able to find out the latest since I could never get my Treo 700W to work with my bluetooth kit in the car! Here is the update:
The 700w does not currently OFFICIALLY support BMW.
We are working with the BMW engineering team at BMW US HQ to figure out the integration. It turns out that the 700w does work but we cannot claim official support due to two major issues on the BMW side (not Palm):
-????????? BMW address book dialer does not support parenthesis characters ?(? or ?)? in a phone number,
-????????? BMW does not support hyphens either;
-????????? However, Microsoft Outlook automatically formats any number to add parenthesis around area code and hyphen between prefix and 4-digit suffix?
All I can recommend is to format the contacts you actually want to use in the car on the 700w to remove the parenthesis and hyphens (dots work) and then it should work. Currently BMW is not sure how to fix the issue but we continue to work with them to hopefully fix for the second OS update (the one that will also add VZAccess Manager support) in late summer 2006.
Currently, with 650, any BWM models other than newer 300 and 500 models will recognize the BMW kit but loose the connection at first attempt to use. Same problem applies with parenthesis and hyphens but many people use Palm Desktop which allows dot formatting. We home to officially support BMW for the 650 in the next OS update late spring or early summer (May?). However, we cannot be sure of success unless BMW engineering finds some workarounds.
Good luck! More to come if I find out more...
JCW
JCW
My Ride: 2007 M6 Coupe
Sapphire Black/Black Merino
Loaded
This is the same Outlook database that was working just fine with my Treo 650 as well.
Originally Posted by GeneArch' post='257943' date='Mar 21 2006, 01:27 AM
Are you sure about this? I just looked at my Outlook data and I have plenty of numbers with parenthesis and hyphens and they work just fine with my E63 and my Blackberry.
JCW
JCW
JCW
Hi JCW,
I followed your advice for my Verizon Treo 650. I have a September build 550i with the software in my car at v. 20. Previously my Treo would loop endlessly with restarts once it had paired with the car.
As you suggested I took out all of the parenthases and hypens and used dots in all of my favorites. The phone then paired and I was able to make and receive calls, but it would often restart at the begging of pairing or when I turned the car off. I then removed the voicemail favorite provided by Verizon ( I was unable to edit it) and put back my own voicemail favorite ( It works just fine, but you cannot assign a speedial of 1, at least I have been unable to do so).
My phone now works seamlessly. I have not had a single Treo restart since going thru the above process. Hopefully it will last. Many thanks for the advice.
HC
HC
JCW
JCW
Ever since switch from my Razor to my now Treo 700W+1.1 Updater Im having the following issue which I hope you may be able to shed some light on... basically the only numbers which are showing up in my telephone list in the i-drive are the picture speed dial numbers... Not my actual phone book on the treo... Not only that but I cannot dial these numbers... they show up but they are greyed out.
Any idea why no numbers from the actual phone book display and/or why the picture speeddial numbers do come up in the idrive system. As far as compatibilty BMW support was supposed to be added in the following update http://www.palm.com/us/support/downloads/t...er/verizon.html
My Ride: 2006 550i, Black/Black, every option except HUD
I'm in ths same situation. :thumbsdown: Has anyone been able to resolve this problem of not being able to view address book entries?
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
Bank$hot530
07-12-2015 04:36 PM
