Switching Treo from Sprint to Verizon
Originally Posted by realtyman' post='235428' date='Feb 5 2006, 11:52 PM
My Treo650 for Verizon works better than my Cingular one ever did. I haven't had any issues with it.
I also have my office "favorite" button which is programed to dial extra digits after the connection (but I need to push a button on the screen to initiate it). Is this what you were talking about? Mine works just fine.
Some time when you are bored - edit your office favorite button and activate the auto dialing of the extra digits and see if your phone loops.
Hi Realtyman,
I have tried every trick I know to get my Treo 650 to work. Do you perhaps have a newer phone with a version of the firmware higher than the 1.04, which is the latest update on the Palm website? Whatever I have tried, including paring my favorites virtually down to zero, my Treo just gets into an endless cycle of reboots. Any ideas or thoughts you might have would be much appreciated. My inalbility to use the bluetooth in my car remains a huge frustration for me.
Harold
[/quote]
I'm looking at mine right now. It appears that I have Phone v1.0
Not sure what your problem is.
Do you have any "dial extra numbers" issues like in the above post?
[/quote]
My version is 1.04 which may be part of the problem. I do not have any extra numbers added to any of my favorites. I can only hope for a firmware upgrade that will fix the problem....2008 if I am lucky with Verizon. Thanks for your input.
I am using version 1.04 - with no issue. If you have a buddy at your dealer, ask if you can sit in a car and try to pair it. That will establish whether or not its your car's bluetooth. Just a thought.
[/quote]
I do - But I dont think it shows up in the car as a saved number. I'll have to look as I leave today. This morning I clicked the dial automatically button again on one of my favorites and it went into the loop. I know you have checked a thousand times - but are you sure none of your favorites have that checked on the second screen. Also, I have replaced all my favorite buttons with numbers - so - some of the favorites that were the camera and the calendar, etc. are gone. I only have names and numbers. Do you still have some of the ancillary stuff on any of your favorite buttons?
[/quote]
I took out all the ancillary stuff in the first two rows of buttons on the main screen and still had the looping probem. I did leave the voicemail in place. I checked every favorite and do not have any set up to automatically dial. I will try and fill the first two rows with numbers this weekend and give it a another shot, but doubt that this will make one bit of differece. Unless Palm/Verizon comes up with a software fix I believe I am doomed.
My Ride: mystic blue 530i, auburn dakota, sport, nav, cold, dob 1-25-2006
Some Questions: Did the fellow who switched get the software patch necessary for the Treo to work put into his car or the phone? Was it a new phone? Harold how old is your CIP? Realtyman same question.
thanks! I am on a blackberry and getting ready for the switch to either non Verizon or Treo with Verizon whatever will work...
David...
David...
My Ride: 2006 Alpine White 550i, Auburn Int., AS, CA, SMG, Premium Sound, Sport Pkg, Cold Weather Pkg, Fold Down Rear Seats, HUD, Navi, SIRIUS, M Body Kit
Yeah does anyone else have anymore insight on this? I have a Verizon Treo 650 and wanted some info on this... Do I need to delete all of the favorites it came with and just store individual numbers or can I just leave it the way it is? I have version 1.04 and would at least like to be connected even if its without my phonebook. Any info would be very helpful. Also, is there anyway you can get SMS on your idrive screen? Or am I just asking for too much?
David...
David...
Harold
There is a software patch that is for the Treo with Sprint...version 1.12 which has to be downloaded into your phone...is this what you did?
