switching to handheld
My Ride: '05 530i-Silver Grey / Grey, Premium, Sport, PDC
How does one switch from bluetooth speakerphone to picking up & continuing the conversation privately on your cell phone. Is there a way without disabling bluetooth connectivity ? cell motov710
My Ride: 2006 525i Jet Black (Base + PDC)
While on an active call via the car, you Motorola phone should display 2 options on the bottom of the screen (on the phone itself). One of them should be 'handset', this should switch your call back to the phone and will not turn 'off' BT connection.
[snapback]185108[/snapback]
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Originally Posted by cidair' date='Oct 17 2005, 01:34 AM
[quote name='vffun' date='Oct 16 2005, 10:17 PM']While on an active call via the car, you Motorola phone should display 2 options on the bottom of the screen (on the phone itself). One of them should be 'handset', this should switch your call back to the phone and will not turn 'off' BT connection.
[snapback]185133[/snapback]
[/quote]On my V600, if I walk out of range of the car, the phone alerts me that the BT signal is bad, and it gives me the option of returning the call to the handset. Pain in the ass, but I just tell the person on the phone to hold on a minute - I get out of the car, lock it and then walk away until I get that option.
[/quote]My SonyEricsson S710a would say something like "Retrieve call on phone" on top of one of the buttons whenever you were on a Bluetooth call. I can't confirm this now because a couple of months ago while on vacation I forgot it was in my swimsuit pocket and went into the pool, never realising it until 15 minute later. ............I'm looking for a used one on eBay now.
I was able to retreive the call onto my Nokia 6230 phone from an active call. So momentarily the call got transferred from the car to the phone. However, about 15 seconds later, the car took control of the call. I am not sure if this is a bug or it is normal for the car to steal it
I know in my bluetooth headset, I can switch the active calls back and forth between the phone and the headset and it will remain that way unless I change it manually.
Originally Posted by UUronL' date='Oct 17 2005, 02:40 PM
[quote name='cidair' date='Oct 17 2005, 01:34 AM'][quote name='vffun' date='Oct 16 2005, 10:17 PM']While on an active call via the car, you Motorola phone should display 2 options on the bottom of the screen (on the phone itself). One of them should be 'handset', this should switch your call back to the phone and will not turn 'off' BT connection.
[snapback]185307[/snapback]
[/quote]Don't know about the Sony Ericsson...but most new Motorola's should work the same (mine is a V551).
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Originally Posted by vffun' date='Oct 17 2005, 05:56 PM
[quote name='UUronL' date='Oct 17 2005, 02:40 PM'][quote name='cidair' date='Oct 17 2005, 01:34 AM'][quote name='vffun' date='Oct 16 2005, 10:17 PM']While on an active call via the car, you Motorola phone should display 2 options on the bottom of the screen (on the phone itself). One of them should be 'handset', this should switch your call back to the phone and will not turn 'off' BT connection.
[snapback]185420[/snapback]
[/quote]I just had a chance to try something I've been meaning to attempt - which is to hit the menu button on my V600 during the call. Lo' and behold, there was an option to move the call back to the handset.
My Ride: 04 545 jet black/beige, smg sport,premium,sunshades,logic7,cwp,nav,pdc,bluetooth,16.0,light tint all around,Pirelli PZeroNero
Is this possible with other phones? I have a SonyEricsson T630.
i also have SE T630 and i can not switch back to handset once i am on Bluetooth,my phone says "Bluetooth connection is busy",the only way i can do it is to shut the ignition of-then Bluetooth off-then restart the car-i do it sometimes while waiting for green light. I suppose i can go to Phone Menu in the CCC of the car but it would take longer and be more complicated.
[/quote]i also have SE T630 and i can not switch back to handset once i am on Bluetooth,my phone says "Bluetooth connection is busy",the only way i can do it is to shut the ignition of-then Bluetooth off-then restart the car-i do it sometimes while waiting for green light. I suppose i can go to Phone Menu in the CCC of the car but it would take longer and be more complicated.
And if u have a cradle it is even easier. A button on the eject box switches between phone and car. Once switched to phone you can remove from cradle and step out of car with phone to continue call.
Vman33
03-14-2022 04:43 AM
Bogdan7
09-23-2015 11:40 AM
Bank$hot530
09-16-2015 01:28 PM
