Swap bta1500 mic for oem microphone?
My Ride: 04 545i
6spd m/t
Sport, Cold Weather, Logic 7
I've installed a gw500 and bta1500. Everything works and I only have to route the mic wires and fix everything into the glovebox permanently.
I don't have BMW assist or nav on my e60, so as far as I can tell the oem microphone is totally useless. I'm considering unwiring it from the car harness and using it for the bta1500 instead.
I don't know much about mic's but I figure it's at least better quality than the dension mic, plus it will maintain the complete factory look (no bta mic poking out anywhere).
Any thoughts?
Any thoughts?
You should be able to reuse the OEM mic. But even the dension mic doesn't need to poke out if you install it above the grill for the mic.
My Ride: 04 545i
6spd m/t
I considered installing the dension mic like that. Do you think it's worth the effort to use the BMW mic instead? It's only a little soldering.
edit: screw it I'll just try it and post the results, it's hardly more effort than discussing it at length ;p
My Ride: 04 545i
6spd m/t
I installed the dension mic over the grill and applied the volume patch, entered ***12 to set the mic volume and everything is great.
My Ride: E60 530D
turbogate
04-11-2015 05:02 PM
