New software available to Nokia 6320 i ?
Hi. Everything is working OK with my Nokia 6230 i, except that only the first number stored on the phone is displayed on the I-drive screen. If I syncronize a SE telephone, or even my new HP IPAQ ALL numbers stored for each person (job, home and so on) comes up. Do'es anyone know if there is a new software version for my phone (the present version is 3.30), that can solve the problem ??
All the best
Peter
All the best
Peter
My Ride: G30 M550i
Model Year: 2018
Originally Posted by plindegaard' post='378164' date='Jan 14 2007, 03:01 PM
Phonebook. If You save it on the SIM ard You can only saven one number, so thats not a solution
Peter
Peter
I see your point Rudy, but then there is no reason to save it on the SIM card, I could do the same in the phonebook.
I know for sure that a SE mobilphone, and also my IPAQ 6915, works, and was just curius if there was a Nokia 6230 solution, because I have a lot of multiple entries in that phone...
Peter
Peter
My Ride: G30 M550i
Model Year: 2018
I understand what you're saying but all I can say is if you want to see all entries on the 6230i, then you'll have to store them on the SIM. Usually, there is a copy function that would allow you to copy entries from the phone to the SIM so it shouldn't be a huge problem for you. If you're planning on waiting until Nokia releases a software fix (I don't think one exists now) you'll likely be waiting an awful long time...
Hi Rudy. Sorry to say: but you are wrong. There is no reason to store it on the SIM. Numbers stored in the phonebook are also displayed on the i-drive screen, but only the first number. So Your "workaround" with storing "Peter Job", "Peter Home" can as well be used by using the phonebook. (as I actually are doing as Nokia can't get to work as SE and HP)
Peter
Peter
My Ride: G30 M550i
Model Year: 2018
If you're able to transfer entries stored on the phone (even just the first one) then sure, you could do it either way. I thought the 6230 only transferred the SIM entries so the workaround made sense. The only real reason to store them on the phone would be to take advantage of the multiple entries, right?
Model Year: 2005
Engine: 545i
Wonky
04-12-2016 08:15 PM
ucsbwsr
09-19-2015 10:58 AM
