Name dialing from phone book
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
I have not been able to dial by name from from my phone book on either my Razor or my v710 both books sync and can be dialed by highlighting but not when i ask by name it says the phone book is empty when it is clearly not what if any solution do i have to get this to work?
Engine: 530i
Originally Posted by Rudy' post='324578' date='Aug 20 2006, 08:29 AM
Do you happen to know what version of software you are running? Will the car allow you to use the "save name" command?
My Ride: G30 M550i
Model Year: 2018
Assuming you don't have navigation, I'm pretty sure that you have to "teach" your car the names/numbers for the voice activated phonebook. I don't have first hand experience with a non-nav car but I think you need to use the "Save Name" command first to teach the car the numbers that you want to use.
Here is a link to the phone instructions (take a look at .pdf page 17 under voice phone book):
http://www.e60.net/information/5_Series_Te...sers_Manual.pdf
If you have nav, there is no teaching needed. The car can "read" the names right from your phonebook and it uses some sort of text-to-speech algorithm to figure out how the names are pronounced...
My Ride: E60 523i
silver, black leather , sunroof , bluetooth , pdc , M sports kit , Steptronic gear box , active stearing , active cruise control
[/quote]
realy thats so cool , must you have pro nav or bussiness nav
[/quote]
Engine: 530i
Thanks Rhudy that worked for me just fine although i wish it would say the names like if you had the pro Nav system
My Ride: G30 M550i
Model Year: 2018
Hi guys,
I have business nav and my bluetooth system is able to "teach" the names via the numbers/save name procedure and phonebook is working perfect, but every time I turn off the key and then turn it on, the stored names are lost and the system tells me that phonebook is empty. I've try it five times, but always with the same effect.
Can anyone help me? ...Rudy?
My Ride: G30 M550i
Model Year: 2018
Not sure what to say -- I don't know how the phonebook data is stored (NVRAM or something else) but obviously something isn't right with your car. Hopefully the dealer or someone else here can figure this one out...
Vman33
03-14-2022 04:43 AM
ucsbwsr
09-19-2015 10:58 AM
