I now have BT - My initial analysis
Old Nov 19, 2004 | 07:35 AM
wassy's Avatar
Of course, thanks to Paul, et al, for starting this quest..
I picked up my car this morning, upgraded to 13.3 and of course, added BT. I expected nothing more than some minor problems as reported from PHarding, and others, who suggest turning the volume down.
Well, after about 1/2 hour of use, and 6 or 7 phone calls, I must say I am extremely HAPPY with the quality of the voices, both ways. In fact, I don't think the problem, at least in my car, was to turn the volume down, but rather, at least on the logic7, the volume can go way way way too high.. so at NORMAL volume levels, it is perfect.
so far, so good. the only thing is I've read here that I can speak the name in the phonebook with NO additional programming, and so far, that is not working!
ANdy
Old Nov 19, 2004 | 07:45 AM
tedmundson's Avatar
My Ride: 2005 530I Prem Package, Cold Weather, Prem Sound, Bluetooth and Sat.
What model phone are you using...
Old Nov 19, 2004 | 11:57 AM
wassy's Avatar
[snapback]58103[/snapback]
v600
Old Nov 20, 2004 | 03:15 PM
Tuga's Avatar
My Ride: 2001 BMW 316ti, 2004 BMW 530d, 2006 BMW 530xd, 2013 BMW 320d touring, 2014 BMW 520d touring, 2016 BMW X5, 2020 BMW 320da touring, 2020 BMW 540i
Model Year: 1974
Engine: Flat six
Mine is working fine with the SE T610. The voice control commands work fine also.
Old Nov 20, 2004 | 04:55 PM
Hormazd's Avatar
Originally Posted by wassy' date='Nov 19 2004, 09:35 AM
Of course, thanks to Paul, et al, for starting this quest..?
I picked up my car this morning, upgraded to 13.3 and of course, added BT.? I expected nothing more than some minor problems as reported from PHarding, and others, who suggest turning the volume down.
Well, after about 1/2 hour of use, and 6 or 7 phone calls, I must say I am extremely HAPPY with the quality of the voices, both ways.? In fact, I don't think the problem, at least in my car, was to turn the volume down, but rather, at least on the logic7, the volume can go way way way too high.. so at NORMAL volume levels, it is perfect.
so far, so good.? the only thing is I've read here that I can speak the name in the phonebook with NO additional programming, and so far, that is not working!
ANdy
[snapback]58101[/snapback]
Huh? You have NAV so its the same CCC computer. If the address book has loaded then you should be able to use the voice dialing. It does take some time, 5-7 seconds to find a match in your address book. Say Dial home or call home.
Can you describe exactly what is or is not happening. Its got to work. Andy I want yours to work as well as mine does.
Old Nov 20, 2004 | 05:07 PM
pharding's Avatar
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
Congrats Wassy !
If you went the Bluetooth route that is an impressive endorsement. I always enjoy your posts.
With voice command, the best approach is to say, for example, "Call Fred". It saves a step. Also with Voice Command, I tend to speak before the symbol pops up indicating that Voice Command is listening. In order for it to work, you have to pause to let Voice Command catch up.
What wireless network and phone do you have?
Old Nov 20, 2004 | 05:25 PM
ZC ED545's Avatar
We should have a bluetooth sub forum
Old Nov 20, 2004 | 06:34 PM
kbuttler's Avatar
wassy, how much did your dealer charge for this upgrade? they are quoting me $400 for labor...is this on par with your charges?
Old Nov 20, 2004 | 06:41 PM
tdocz's Avatar
Will the razr by motorola work with the E60 Blue tooth?
I have it on order and my 05 replacement 545 will be hear I hope in 3 weeks
Old Nov 20, 2004 | 06:45 PM
wassy's Avatar
I got a complimentary upgrade since they had to do other things as well.
also, have Tmobile w/ V600. As far as endorsing Bluetooth, I always did. that is why I was so very upset that there might have been some quality issues, as I had on the X5.. Happy to say, so far, really, so very good!
believe it or not, i would almost say it is as good as the hardwired.. maybe i got lucky?
as for voice dialing.. got it.. problem though is lets say my phonebook say Harding Paul (yes, last name first)... and I say Dial Name, Harding Paul, it has difficulty doing the last , first thing... and recognizing the name, and what do i do about Harding Paul office and Harding Paul Home? (example only!)
thanks.
