How to add Mulf2
My Ride: BMW 550i
How to add Mulf2
My car is a 2006 550i E60 that does not come with phone nor bluetooth.
I open the trunk and try to find if it has built-in MULF or TCU, there is no such device installed there.
Is it possible to add MULF2HIGH to enable bluetooth phone connect and music stream?
I can buy a mulf2 device to install if needed.
Thanks
Thanks
My Ride: 2006 525i
Model Year: 206
for a 2006, I doubt if you can install MULF for music streaming. Mine is 2006 too with M-ASK and I only have bluetooth phone, no music streaming.
My Ride: E60 550i
Model Year: 2010
music streaming is not possible with MULF module. Music steam was not possible with stock options from BMW. They enabled music stream with combox which can be retrofitted if you have CIC navigation only. In your case you can opt for an aftermarket solution for both music and handsfree bluetooth stream. Music stream can be done on cheap via AUX input.
My Ride: BMW 530xiT (E61)
have you read through this thread:
https://5series.net/forums/bluetooth...eaming-139872/
there appears to be a relatively simply option for adding bluetooth streaming
