Enable bluetooth 04' builds
Quick question for you guys just bought my 530 yesterday and after searches last night went in knowing what to ask/do for BT. Anyway found a tech that knows how to do it, the shops master I gues but the problem and converstion went as follows he said it's no problem but half the time the CIP ugrade crashes and a new TCU would be needed. He said this would be my responsibility if this happened, I asked if there might be a recall upgrade that would be needed anyway so they would have to do it and could just anable BT and if somerhitn went wrong and the TCU would need replacing it would not be my fault. He said sure but had service do a VIN search and no recalls. What should I do???
My Ride: G30 M550i
Model Year: 2018
Here's my answer that to your cross-post of this question:
http://forums.e60.net/index.php?s=&showtop...ndpost&p=219735
(BTW, you shouldn't have to cross-post your questions, most of us read new posts across all forums so you'll get an answer, I promise!)
New member here. I bought a 04 about a year ago and was under the impression that it was bluetooth capable. Even had a card with bluetooth info. Well, finally got a bluetooth phone and figured out that I didn't have it or it was not enabled. I called a couple of dealers before I found this site and one said I cant get it the other said he would look into it a call me back. Can someone give me a definative answer on what it would take to get bluetooth enabled. Using info here I figured out that my car was built in 07/04. Based on what I have read I think I just need a software update. Can someone confirm? Glad I found this site. Thanks in Advance.
My Ride: 2011 F10 535i -Brilliant Graphite/Oyster
2006 E5004matic- I must have been on drugs when I got this car
2004 545i Black Sapphire/Truffle Brown interior
You are indeed correct, should only be a software upgrade to the communication portion of the software, which should not be any more than $ 200.00. Just make sure that your Cell Phone is compatable with BMW Bluetooth. If you care to post your make and model, someone here should be able to confirm their experience with same model Cell Phone. Good Luck
I had recently bought an 530i, my build date was 12/04. I have the BMW assist on the vehicle so it has the microphones and stuff. Will BMW charge an ridiculous amount to change the software on the vehicle? I have an Verizon LG VX8100. Does anyone else use this phone with BMW or is it not compaitble?
wait a minute. Im getting confuse here.
I got delivery of my car on 3/04 and I dont have NAV in my car. Can I still enable the bluetooth with only software upgrade?
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
Hmmm, Not sure what you guys are describing, at such cheap prices; but the all new BT adapter that plugs into the CPT 9000 cradle etc. alone, is $295, the cradle is another $110 or so, and the software service is another $20 (to fire up CPT 9000 in iDrive). This is about what my dealer is charging me next week, as I have never had phone service in my early 04, so I have to start from scratch (with my E815 Verizon phone) Also, he will do an update of CIP and see what's left to be done for phone after that.
If you order your parts from the RI dealer (see parts and accessories board), you can get 20-30% off these pieces, however, you still need to go to the dealer for activation. No fool here: the last DIY chore I'll tackle is an electronic one on this car....
Cheers,
Ray Hul
See my thread below here on the announcement of the adapter.
Cheers,
Ray Hul
ucsbwsr
09-19-2015 10:58 AM
