During sw upgrade, failed mic which made them
Old Dec 19, 2004 | 03:49 AM
Almighty JungleBoy's Avatar
When my car was brought in for emissions recall, they updated my software, which then caused the microphone to not work, so they said they will hold the car longer because they will change module due to that... what module will they be changing? very curious....
Old Dec 19, 2004 | 04:21 AM
JDN's Avatar
JDN
The dealer is likely replacing your CCC (with NAV) or M-ASK (wo NAV) unit. That is the main iDrive unit.
Old Dec 20, 2004 | 03:02 AM
so would that new CCC upgrade be a change to a newer module that is Bluetooth compatible? just curious, because mine is a pre-March/2004 build....
Old Dec 20, 2004 | 04:07 AM
gdavis's Avatar
It may be the TCU unit (telecommunications unit) in the trunk that makes it compatible. Of course the other part that is required for BT is the v13.3 software in the idrive (CCC or M-ASK) and also to be set up for BT use.
Old Dec 20, 2004 | 09:13 AM
dstompkins's Avatar
[snapback]70711[/snapback]
No...Pre-March '04 production cars need more than just a software/ccc update...I have seen no definitive answer but so far, so suggestion has been made that pre March cars will ever be able to have Bluetooth.
Old Dec 21, 2004 | 03:22 AM
thanks guys for replies!!
so if they DID change my "module" which might be the TCU itself, would I be falling into the same category of people whose cars are post-March 2004 where I need only software upgrade and wiring?
how can I confirm if they DID change the TCU and not any other module? thanks again guys!!
Old Dec 24, 2004 | 11:05 PM
anonymous
Guest
Posts: n/a
so would he need to just get software with BT update without having to change any TCU or new module?
srogers535x
Aug 5, 2015 08:48 AM
vards01
Jul 12, 2015 05:33 AM
Inty
Jul 9, 2015 09:48 AM
cnwakobi
Jul 9, 2015 09:46 AM
pantzjantz
Jul 7, 2015 04:44 PM
