can you play music through bluetooth? 04 530i
I have a 530i 2004 and I plan on taking it to the dealership to get it updated for the bluetooth. Now my queston is if it will play music through it.that's the only reason I want it.
My Ride: 530i
Engine: M54
retrofit an AUX input. you can buy the kit from BMW for less than $100, or build your own wiring for about $8. a retrofit will require coding, so you'll need to find someone capable of coding it for you or have the dealer do it.
My Ride: '98 Lexus GS300 Prev Ride: '07: 550i
Could you explain what that is and what it does?
It's a bluetooth audio dongle. Take the cap off and it has a USB plug. You can plug that into a usb charger. I prefer the smaller ones like this:
![](http://thumbs3.ebaystatic.com/d/l225/m/mFEPiqgke4gBUB3lWgEG7Rg.jpg)
That circular hole is for a standard 3.5mm audio cable which you run from that to the aux in hole in the car.
Of course, you must pair your audio device(phone) to the bluetooth dongle. There is usually no passcode and you only have to pair it once as the connection is remembered.
Then in IDrive, you select auxillary input and you do any and all controls on the phone. If you have a decent phone mount, it's easy, safe and legal to control.
Also what would sound better the aux or using this Bluetooth dongle?
