can you play music through bluetooth? 04 530i
I have a 530i 2004 and I plan on taking it to the dealership to get it updated for the bluetooth. Now my queston is if it will play music through it.that's the only reason I want it.
No. It won't. Only voice connectivity. If you want music playback, you'll need a whole new interface. Dension is a good place to start.
Originally Posted by gbrldz
(Post 1544948)
Used any weres from 240-300$. New I believe $500. Were In jersey u located ?
Originally Posted by Bigjule111
(Post 1544973)
Originally Posted by Jersey
(Post 1544988)
Used to live in jersy. Now I live in el paso, texas. Is there anything cheaper to play music through your phone in the car without bluetooth? Anything in the 100$ range?
If you don't already have an aux input, do that. Then pick up one of these on ebay for $6. Plug it into a micro usb charger in the cig lighter. Done.
http://i.ebayimg.com/00/s/MjMzWDMwMg...9T4HRR/$_1.JPG Then of course you can hack it all up to hide it in the center console. |
Originally Posted by insyder
(Post 1545008)
[URLhttp://i.ebayimg.com/00/s/MjMzWDMwMg...9T4HRR/$_1.JPG[/URL] Then of course you can hack it all up to hide it in the center console. |
It's a bluetooth audio dongle. Take the cap off and it has a USB plug. You can plug that into a usb charger. I prefer the smaller ones like this:
http://thumbs3.ebaystatic.com/d/l225...B3lWgEG7Rg.jpg That circular hole is for a standard 3.5mm audio cable which you run from that to the aux in hole in the car. Of course, you must pair your audio device(phone) to the bluetooth dongle. There is usually no passcode and you only have to pair it once as the connection is remembered. Then in IDrive, you select auxillary input and you do any and all controls on the phone. If you have a decent phone mount, it's easy, safe and legal to control. |
(Post 1545011)
http://thumbs3.ebaystatic.com/d/l225...B3lWgEG7Rg.jpg That circular hole is for a standard 3.5mm audio cable which you run from that to the aux in hole in the car. Of course, you must pair your audio device(phone) to the bluetooth dongle. There is usually no passcode and you only have to pair it once as the connection is remembered. Then in IDrive, you select auxillary input and you do any and all controls on the phone. If you have a decent phone mount, it's easy, safe and legal to control. Also what would sound better the aux or using this Bluetooth dongle? |
