Bluetooth - Two Phones at Once?
Old 02-15-2010, 03:36 PM
Ace_1's Avatar
I've been able to pair two phones to my car but when both my wife and I are in the car the Bluetooth can only access and use one phone at a time.
Is there something wrong with my Bluetooth?
Thanks in advance!
Old 02-15-2010, 04:11 PM
Gene's Avatar
if you mean access via iDrive one phone at a time, I believe that is correct. I do not think you can access both phone books simultaneously via iDrive and/or obviously both be connected via BT to 2 different calls at the same time....
Old 02-15-2010, 05:07 PM
luigi524td's Avatar
Thanks in advance!
BT (currently) cannot pair two devices simultaneously .... The first phone recognized / detected will be the one paired - unless, of course, you turn off BT on the phone. I think in iDrive you can also disconnect one phone and select which phone you want to pair with the car.
Vman33
03-14-2022 04:43 AM
CHRGRS_BMW
38
09-01-2016 09:39 AM
Deano
09-28-2015 10:15 AM
ucsbwsr
09-19-2015 10:58 AM
Quick Reply: Bluetooth - Two Phones at Once?
