Bluetooth Operation Question
For you guys with Bluetooth. If your phone is paired with your car and an incoming call comes in, the radio goes mute and the I-Drive display shows
"Incoming Call" Accept or Reject.
At that point, when you choose Accept, are you suppose to be able to use the cars microphone to answer the call?
I had access to a 05 525i and paired my phone to the car, an incoming call comes in, the radio goes mute, I select "Accept" on the I-Drive but my phone is still ringing. I'm pretty sure the phone isnt as compatible as the Motorola but I wanted to verify with someone with a working bluetooth setup that after selcecting accept, you can talk using the car's mic.
thanks
thanks
thanks
thanks
[snapback]103937[/snapback]
My Ride: Born Date 9, 1 2004. 2005 530i, silver gray, steptronic, nav, Adaptive xenon, premium pkg, cold weather pkg, premium sound pkg, Euro rear reflector. MP3 Enabled
thanks
thanks
