Bluetooth Bug
![Smile](https://5series.net/forums/images/icons/icon7.gif)
I am having this problem when a phone call comes in/goes out - the radio/cd did not mute; this happens only after CIP 16.2. :'(
Many a times, I can't seem to hang up the line even after I opted to Hang Up or when the other party hangs up.
Ended up unchecking bluetooth and rechecking it, otherwise the "little antennae" keeps blinking on the iDrive screen and refuses to disconnect.
Is this a bluetooth bug in CIP 16.2?
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
My Ride: 2004 545i alpine white/beige, sport package, nav, premium sound, cold weather
Originally Posted by Olivin530i' date='May 15 2005, 06:29 AM
I am having this problem when a phone call comes in/goes out - the radio/cd did not mute; this happens only after CIP 16.2.? :'(?
Many a times, I can't seem to hang up the line even after I opted to Hang Up or when the other party hangs up.?
Is this a bluetooth bug in CIP 16.2?![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
[snapback]128744[/snapback]
Originally Posted by msterzer' date='May 15 2005, 07:38 AM
I just had 16.2 installed and had bluetooth enabled at the same time. Mine is working perfectly.
Originally Posted by wnrussell' date='May 15 2005, 03:03 PM
[quote name='msterzer' date='May 15 2005, 07:38 AM']I just had 16.2 installed and had bluetooth enabled at the same time. Mine is working perfectly.
[snapback]128753[/snapback]
[/quote]So is mine, but I never had Acoustic Confirm, only flash light on Lock/Unlock and BT and Lock/Unlock Confirm are well working after 16.2 , crossing fingers.
My Ride: '06 550i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, Active Steering, Comfort Seats, Comfort Access, HUD, Alpine White on Black Dakota & a Big Grin ;-) <---- On the vessel from Germany...
'05 545i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, UUC EVOIII SSK, Silver Gray on Black Dakota..... (Buy back by BMW NA)
I have the same problem with the BT after the upgrade !!
![Post](https://5series.net/forums/images/icons/icon1.gif)
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
I've been using 16.2 for about a month now and have had no problems, and am using Bluetooth in the car more and more.
Robert
I'll most likely get this bug since we're using the same Siemens S65.
Arrrgh, this means I'll have to wait longer to get mp3 playback in the CD :'(
eggz,
go ahead with the upgrade and remove the annoying warning message.
It is worse than the b/t bug (if there is indeed one).
I've had this problem for some time and I do not yet have 16.2
Sometimes it works to disconnect the line if I press the 'knob' and select 'end call'. It can be very annoying.
I also can end up with calls being re-dialed even when I don't initiate the call.
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
