Bluetooth....?
Originally Posted by ademitt' date='Aug 29 2005, 02:34 PM
[quote name='alohalc' date='Aug 28 2005, 07:11 PM']daveyboy, based on your sig, yours built 06/04 and i think all you need to do have the dealer to update the sw.? you can tell them there is something wrong with your idrive and they'll update it under warranty.? however, this doesn't mean they'll activate the bt for you.? they might charge you labor for that.? but let them charge you more than 2 hours and there is no other parts needed.
[snapback]164518[/snapback]
Alohalc is absolutely correct. There should be no hardware required given your build date. Have your dealer activate the BT in your software and you should be good to go. Your car is new enough that you should not need a software update.
[snapback]164813[/snapback]
[/quote]So does that mean that i may have BT also considering my build date? Anyway i don't have any BT in communications! How much would a dealer charge to activate it??!?
PLS PLS i hardly wait for an answer
My Ride: G30 M550i
Model Year: 2018
[snapback]165087[/snapback]
Use the following link for instructions"
http://www.e60.net/information/5_Series_Te...sers_Manual.pdf
kirk7
Bluetooth & Cell Phone Forum
13
09-12-2009 12:32 AM
kirk7
08-06-2009 02:38 AM
